Need help! Still misfiring :(
07-08-2016, 09:39 PM | #1 |
Rep 59
Hey guys....been having this misfiring problem for a couple of months with my e90 335 and it's driving me nuts because I can't figure it out. Within last couple of weeks I put new plugs and coils, also had a walnut blasting done 2 days ago. Every time it misfires always says cyl 4 misfire and power management standby control and goes into limp mode. When I drive normally it's fine but as soon as I start boosting it starts misfiring and check engine light comes on. The garage wants to do a compression test and a leak down test but does anyone have any other ideas? Helppppp please.....thanks!
07-08-2016, 10:05 PM | #2 |
88
Rep 243
the electrical code doesn't have anything to do with it. it's from one of the aftermarket electronics you have plugged in
if you already changed the plug and coilpack, the only thing left is the injector |
07-08-2016, 10:25 PM | #3 |
Rep 59
Well when it started happening i changed the injector for cyl 4 and its stipped for a few weeks. Im mhd stage 1 tuned with 91 oct. I flashed back to stock for now because i cant even boost anyways. I was think it might be because cyl 4 injector is index 12 and all the others are mixed between 7-9. The garage told me it doesnt matter that they are different index but from what i have been reading apparently it does. He also had check my injectors and number 4 wasnt codes and all the other ones values were way off. He re coded all of them and still same thing.
07-08-2016, 11:39 PM | #4 | |
186
Rep 927
07-09-2016, 02:52 AM | #5 |
2899
Rep 3,729
Can you post a log?
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
07-09-2016, 04:24 PM | #9 |
Rep 59
Only under boost......i can drive the car all day normally and as soon as i start boosting it starts misfiring and goes into limp mode and says cyl4 misfire
07-09-2016, 07:50 PM | #10 |
4ut0strd4
47
Rep 223
For me it has been a coil every single time (knock on wood), is the gap off on one of the plugs? Unlikely, but that will definitely cause this issue. If you are on oem plugs like me that's highly unlikely with all the ground electrodes, but more likely on ngk's.
07-09-2016, 07:52 PM | #11 |
4ut0strd4
47
Rep 223
Really hope it's not a ring land on that piston or something, my guess is that it's fuel related if everything else has been changed like a fuel sensor possibly. More info on codes, tune, mods, power level, and everything else will help.
07-09-2016, 08:02 PM | #12 |
Rep 59
Plugs and coils are brand new! I was running mhd stage 1 91oct but i flashed back to stock and everything else is stock. Codes are always the same....cyl 4 misfire and power management standby control (limp mode). Its weird because if i am just cruising its absolutely fine but as soon as i step on it and it starts boosting thats when it misfire. It will also idle abit rough sometimes. Car is a 2009 335xi with 107,000km not miles
07-09-2016, 11:57 PM | #14 |
2899
Rep 3,729
Have you done a walnut blast before?
07-10-2016, 12:26 AM | #16 |
2899
Rep 3,729
Do you have any secondary codes or is misfire cyl 4 the only code you are getting?
07-10-2016, 06:57 AM | #17 |
122
Rep 397
07-10-2016, 08:46 AM | #18 |
Rep 59
Codes are cyl 4 misfire and also power management standby control. We didnt do a compression test or leakdown yet. I was talking about reading the values on a scanner. Every cylinder was fluctuating between -1 and 1 but cyl 4 was around 3-4.
07-10-2016, 09:52 AM | #20 |
915
Rep 3,456
Drives: Harrop E90 M3
You can't mix injectors over and under index of 11 on the same bank. Replace the injectors on 5&6 then see how it runs. Code them correctly and clear your adaptations.
07-10-2016, 10:01 AM | #21 |
380
Rep 1,497
X2 on this. Either get 11 of higher on 5 and 6 or replace 4 with 10 and lower index. Dont forget to grt them coded
07-10-2016, 10:19 AM | #22 |
Rep 59
We pulled the plug on cyl 4 and it looked normal. I told the mechanic i was reading online how index 12 cant be mixed with index 8 or 9 and he said it doesnt matter. I think that that's the problem though.
