BMW X3 Forum
BMW X3 Forum
      07-08-2016, 10:56 AM   #1
evilken
Drives:
White smoke from exhaust on Startup
So my 2013 X3 started having the white smoke on startup issue a little bit ago. It is out of warranty with 53,9xx miles on it. Took it back to the dealer to have it looked at. It happened to be a leaking Turbo Oil line which quite a few have experienced here. The reason for this post is that BMW NA stepped up and paid for everything for this fix. I didn't have to do anything and this was all initiated and handled by the dealer. Obviously, I can't vouch that this is BMW NA policy, but if any of you experience this issue and is your car is Out of Warranty, give it a shot.
      10-04-2016, 01:02 PM   #2
msf
Keep the shiny side up.
Drives: 2013 135is
Turbo Oil Line
2013 X3 28i turbo oil line replaced at 44,700. Lots of smoke at start up. Intermittent problem caused by oil pooling in line. Known issue.
2013 X3 28i, BSM, Chestnut, Premium pkg, Convenience pkg, Cold pkg, Dynamic pkg.
2013 135is, DCT, BSM, Blk/Blue, Premium pkg, Tech pkg, Heated seats, HK
      10-04-2016, 03:10 PM   #3
Portimao318
Portimao318's Avatar
61
Drives: BMW 318i Touring MSport
Do you know how much that repair would have cost you if BMW would not have taken care of it ?
2022 318i Touring MSport Portimao blue
      10-06-2016, 08:36 PM   #4
dreaming440i
22
Drives: 2017 440i Gran Coupe M Sport
I now have these symptoms. It only shows up after sitting for more than two days. A month ago out was out of town for 2 weeks, and when I started it up it was like a white smokescreen behind my car. It has since happened twice, when my car sat over the weekend. I have it in the dealer right now.
Oh, 2013 28i with 40k miles.
      10-07-2016, 09:13 AM   #5
Bruce24
12
Drives: X3 2.8i
Had the same issue with my 2013 28i first noticed the smoke at 42K miles. Took it in, showed them a video of the smoke and they ended up replacing the oil supply line for the turbocharger.
Not sure of the cost since it was covered under warranty.
-Bruce
      10-08-2016, 07:59 AM   #6
Tomlomcom
Drives: X3 2014
Had same problem with u guys 6 months ago .. dealer replaced turbo under warranty ..
      10-09-2016, 01:07 PM   #7
E90Fleet
South Africa
1312
Drives: BMW
BMW NA has extended the warranty on the Turbo oil pipe causing this problem on N20 engines
"SIB 11 11 16" makes the North American Warranty now 10 years/120,000 miles
BMW if you are reading, I need a job, Please.
      10-20-2021, 11:09 PM   #8
rknox
Drives: 2013 x3 28i
White Smoke from Exhaust
FYI, 2013 X3 28i, now with 73,000 miles started exact same problem a year ago. White smoke from exhaust. The more days it sat without use, the more white smoke. Also oil dripping from exhaust pipe onto driveway. Expected a fight with dealer but turbo line was replaced under warranty -- no charge.
xbimmers
