Tips on changing spark plugs and coil packs
07-07-2016, 07:24 PM | #1 |
74
Rep 295
Just ordered me some Bosch spark plugs and coils. Wanted to see if you guys have any tips on changing the spark plugs and coils on a 328.
07-07-2016, 07:28 PM | #2 |
147
Rep 500
07-07-2016, 07:39 PM | #3 |
7409
Rep 10,215
Buy yourself a magnetic spark plug socket.
Antetokounmpo1551.50 |
07-07-2016, 08:35 PM | #4 |
48
Rep 244
Drives: E90 M3
If you have a spark plug socket but its not magnetic, after unscrewing the spark plug and it is free, use the coil pack and push it onto the spark plug. It will come up with the coil pack.
07-07-2016, 10:31 PM | #5 |
Roll Tide
591
Rep 2,345
Make sure you have the proper thin-walled spark plug socket. Nothing sucks worse than having to put the car back together and do the job twice. Just take your time and don't force anything. The most difficult part is probably remove the coils. After you flip the switch up and remove the electrical connector, put a large flathead screwdriver through the switch hole and pull straight up. And when you go to re-seat the coils, make sure they're pushed all the way down.
Good luck! |
07-08-2016, 08:06 AM | #6 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
MAKE SURE YOU CHECK THE GAP SPARK PLUG GAP! I can't remember the proper gap (I'm sure you can google this) but they should be checked with a simple gap tool you can get anywhere.
07-08-2016, 08:31 AM | #7 |
1705
Rep 14,829
When undoing the cowl, be careful with the wiring loom and the air quality sensors. On the pass side I disconnected it rather than try to get it off the lower cabin filter housing. The driver side unclips. I forgot this when doing the ABS pump and the sensor snapped out on the pass side, functions but maybe 1/2 mm of plastic snapped (good ol' duct tape got it back in place).
Also, I prefer to use a locking 3/8" extension so you don't lose the thin walled socket. Because of the #5 cyl, it can't be too long, I dunno, 4 or 6". Mine was like 10" and too long. This doesn't seem to be something we can agree upon, but I follow the factory recommendations. NEVER USE ANTI SEIZE TORQUE TO 17 FT LBS. Your torque wrench needs to have an upper range of no more than 75 ft. lbs., since they are only accurate down to 20% of the upper range. People are gonna crawl out of the woodwork who say, "I've been building race cars since 1988 and I always use anti seize and I never use a torque wrench. Torque wrenches are for people who don't know what they're doing, unlike me. I eyeball it and it has always been fine." That's just not what I would do. One guy went so far as to say there's a conspiracy between Bosch and BMW in telling you to never use anti seize and use a torque wrench, as if they want repair work when you break the plugs, that is so far fetched.... Good luck, and don't forget to reset your CBS.... |
07-08-2016, 08:58 AM | #8 |
17315
Rep 18,737
I've been building race car engines since I was a wee lad of ....
Kidding (but I've done a few plug changes in my time, and 3 on the N52). Here's my advice for the N52 engine, which is what you have in your car. You need a regular 5/8 sparkplug socket, vs. a "thin-wall" socket, which is only necessary for the N54/55 engine. The sparkplug socket should be either magnetic or have a rubber bushing in it that grabs the plug. I suggest you use electrical tape and tape the socket to the extension bar because sometimes the socket won't release from the plug before it releases from the extension bar. There is really no need to use anti-seize, but if you do, just a small amount and use copper anti-seize for high-temperature applications. Upon install, hand-install (hand thread-in) the plugs (i.e. don't use a socket wrench to thread the plug into the head, just use the socket attached to the extension bar). Once the plug stops threading then use a torque wrench to seat the plug, which really only is crushing the sealing washer on the plug to the head. If there is any resistance to hand threading the plug, immediately stop and unscrew the plug and start over. Any resistance indicates the plug is cross-threading into the hole, this is why you don't use a wrench, so you can feel if the plug is cross-threading; it should smoothly thread into the cylinderhead. I highly recommend using a 3/8-drive bar-type torque wrench for setting the plug torque because bar-type torque wrenches are more accurate at low torque values than a click-type torque wrench. The coils can be a bit intimidating the first time you try to remove them. They have a funky cap that snaps open/closed and pushes/pulls the connector in/out of the connector socket of the coil. Sometimes you need to pull the connector out while lifting up the cap. The cap has a finger-ring opening in it to assist in pulling the coil up off the sparkplug. You can use a screw driver in the finger-ring to lever up the coil if it is stuck to the plug.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
07-08-2016, 09:44 AM | #9 | |
1705
Rep 14,829
Starting by hand was really good advice also with the ABS pump and the 6 brake lines, because if the brake lines do not thread by hand, something is wrong... That's one where I did not use a torque wrench, and did it by feel with the line wrench... |
07-08-2016, 10:10 AM | #11 |
2341
Rep 3,539
Have penetrating oil handy.
My cylinder 6 plug was seized. Had to make a trip to the store to get penetrating oil. Spray some around the plug and let sit for about 15 mins. Plug will come out no problem. Have a shop vac handy. Once you pull the plugs, you'll notice black build up chucks that are now loose and sitting on the threads of the head. With a shop vac and a straw attachment, vacuum all that junk and then place new plug in. Cheers |
07-08-2016, 10:13 AM | #12 | |
17315
Rep 18,737
07-08-2016, 11:32 AM | #13 |
340
Rep 922
Agreed. Getting the connector on the coil to "click" is difficult and you might feel like you'll break it. Go slow and don't force anything.
2006 330i 6MT Jet Black / Black
07-08-2016, 11:36 AM | #14 |
705
Rep 2,605
I applied some di-electric grease on the connector of the coils to the plugs to help ensure there was a good electrical contact between the two parts.
07-08-2016, 12:36 PM | #15 |
1705
Rep 14,829
I actually bought a spare coil pack just in case, but did not run into any issues....because I wanted to know what I was dealing with ahead of time, first and only change for me thus far...
07-08-2016, 03:54 PM | #16 | |
65
Rep 285
BMS DCI/M FMIC&OCC/KONI YELLOW/H&R Sport/Hotchkis Front Sway&Links/CORSA Catback/VRSF CP/TS BOV
07-08-2016, 09:35 PM | #17 |
118
Rep 424
Make sure to have a short rachet extension for cylinder #5.
Also there are 4 screws that need to be removed to take the engine cover off. I didn't replace the back two just to make my life easier. |
07-08-2016, 09:59 PM | #18 |
65
Rep 342
Drives: 2007 335i E92
Well your first mistake was getting a 328i, should have gotten a 335i or m3. 328i's are worthless scrap metal.
07-08-2016, 10:19 PM | #19 |
Enthusiast
167
Rep 1,622
07-08-2016, 11:31 PM | #20 | |
186
Rep 927
07-09-2016, 12:33 PM | #21 | |
2341
Rep 3,539
Your bmw ownership history in years? Cars owned? First build some credibility before you start talking shit, especially when you just joined the forum. Edit: just looked you up, you're 16. Now it all makes sense. Saw your thread and again it all makes sense. Last edited by Wolf 335; 07-09-2016 at 12:39 PM.. |
07-09-2016, 05:25 PM | #22 |
74
Rep 295
Thank you guys so much for all the info, it helped a lot! I got the job done , had some problems with putting back some stuff on but none the less was a easy job! This is why i love e90post , thanks guys!!!
