Weird steering squeak
07-06-2016, 07:23 AM | #1 |
213
Rep 1,782
So after trying to lubricate the U-joints multiple times I finally figured out that the squeak is coming from the rubber boot on the steering column. It's the first thing you see when you take off the panel in the footwell area. You can see it in this video. https://youtu.be/gRH8caDH_uE
I tried 3 different lubricants. Silicon spray, u-joint grease and dry graphite. But the squeak always comes back after a short time. Any suggestions? Maybe a piece of tape or something?
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
07-07-2016, 07:09 AM | #2 |
213
Rep 1,782
Bump
07-07-2016, 05:55 PM | #3 |
1007
Rep 2,108
For such rubber Honda ShinEtsu is very high quality grease, worth its price:
https://www.amazon.com/Genuine-Honda.../dp/B00GD49GTS I used it there, squeak didn't return for couple of years now. You need to get in there though, all between the shaft and the boot. |
07-07-2016, 08:29 PM | #4 | |
213
Rep 1,782
07-09-2016, 05:02 PM | #5 | |
213
Rep 1,782
07-11-2016, 06:37 AM | #7 | |
213
Rep 1,782
It sounds like a normal flywheel during normal shifts but shifting at redline it sounds nice and racey like raspy sounding which you can hear within the cabin with the windows up. So overall it's a nice upgrade which I'd recommend considering during your next clutch replacement.
