Are inlets worth it?
07-05-2016, 10:17 PM | #1 |
16
Rep 104
Currently on oem turbos, downpipes and stage 2 MHD tune. FMIC on the way as well so will be stage 2+ shortly. I was thinking about inlets but I am not to sure if it is worth it. What type of gains can I except with inlets on stage 2 ots map. Will I need to get a custom map to see any real gains? Will I be able to gain around 30-40hp from inlets on a ots map? Not sure if I should go with inlets or just pass and get myself some wheels??
07-05-2016, 10:31 PM | #2 |
44
Rep 238
Long story short, yes they're worth it. Can expect 30-40whp gains
2009 Monaco Blue BMW 335 XDrive, Beyern 18s, KWv1, MHD, VRSF Full, ARM FMIC, BMS DCI, Stett CP, Forge DVs, Stage 2 LPFP, BMS OCC, (soon) M3 Rear Sway, VTT Stg 2, MMP Inlets
JC_AD335i27.50 |
07-05-2016, 10:39 PM | #3 |
16
Rep 104
I guess that is good to hear haha. From reading around I just read that I will see minimal gains with inlets. But if I am going to be able to get around 30-40hp I guess it is worth it.
07-05-2016, 11:05 PM | #5 |
406
Rep 574
07-05-2016, 11:44 PM | #6 |
44
Rep 238
Haha I should have said atleast 30-40 hp
07-06-2016, 06:14 AM | #7 | |
330
Rep 984
07-06-2016, 07:19 AM | #8 |
47
Rep 113
I think it depends. If you really want to push the envelope then sure, but my inlets didn't fit well; they're wedged between the engine block and the firewall and eventually they're going to wear through. I'm not sure what I'm going to do once that happens. After seeing the fitment I realized I would have been better off leaving well enough alone. This is what my tech had to say about them: "Those silicone pipes are $hit!".
07-06-2016, 08:00 AM | #9 | |
100
Rep 1,040
Please do some research and look at the dyno slips folks have posted on this forum before making asinine claims like that. Way too many people like you who have never dyno'd their car chiming in with dyno claim numbers based on uneducated guesses. There are a few sheets posted here showing 40+ whp on stock turbos no "custom tuning." Unless I'm wrong, I'd be happy to see your dyno slips, as would everyone else here.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
WeekendWarriorz670.00 JC_AD335i27.50 |
07-06-2016, 08:20 AM | #10 | ||
318
Rep 516
Look for the dynos and threads across this and other forums. Stock turbos without inlets max out at 450whp, with inlets 500 to even 514whp has been reported by several maxing out. Stage 2 turbos maxed out at 550whp prior to inlets, after inlets the same turbos made up to 680whp, with tuning and fuel. |
JC_AD335i27.50 |
07-06-2016, 10:11 AM | #11 |
16
Rep 104
So many mixed opinions haha I'm not sure what to to. I've looked up some dynos with stock turbos inlets and 93oct. I saw frankenturbo had no power increase but have also seen mmperformance dynos with power increases. I've also heard that I won't really see gains unless going e85 etc. I plain on staying with 93oct and not really looking to get a custom tune. Makes me wonder because I won't really be getting full potential out of them without either of those.
07-06-2016, 10:37 AM | #12 | |
330
Rep 984
Greg Noble is from the BMW Drivers Club in NSW Australia and it clearly says 30WHP gain on RBs with no tuning change, which is exactly what I said. |
07-06-2016, 10:42 AM | #13 | |
330
Rep 984
07-06-2016, 10:44 AM | #14 | |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
07-06-2016, 01:10 PM | #15 | |
406
Rep 574
07-06-2016, 01:19 PM | #16 |
200
Rep 2,799
There is power to be gained and the car will feel a lot more responsive down low. I was in the same position as you, OP and ended up going with them. Your wgdc will drop a great amount, your turbos will love you.
thanks to MGallop |
07-06-2016, 01:22 PM | #17 |
62
Rep 944
07-06-2016, 02:00 PM | #18 |
330
Rep 984
07-06-2016, 02:22 PM | #19 |
184
Rep 232
I don't know about this dramatic hp gain others talk about, but I do know that they dramatically reduced my wgdc. As the engine gets into the higher rpm's, boost is higher than before, and wgdc is much lower. This is very apparent from my logs, so in that regards I'm happy.
07-06-2016, 03:34 PM | #20 |
144
Rep 439
Drives: 07 E92 335 / 17 F16 X6 35i
@mikecentola
07 335i SG / CR - LOTS OF MODS - BUILD THREAD 17 X6 SG / LCSW - ZMM/ZCW/ZDA/ZDB/ZLP/ZPP/MPPK - H&R VTR / Vossen 22x10.5/22x12 18 Ford Raptor |
07-06-2016, 03:44 PM | #21 |
3441
Rep 79,211
Inlet manufacturers and customers boasting them should really post up dynos to prove their worth. I believe they work but that's not the point here.
A controlled test would be the following variables: -Current Tune -Current Tune modified with increased boost (possibly timing too), possibly showing losses in power or elevated WGDC -Current Tune with inlets -Current Tune with inlet with increased boost (possibly timing too), showing potential power gain and reduced WGDC When we say maxxed out turbo's are we talking about glory run numbers that aren't realistic on the street. I can turn up my car on 93 octane, no meth and see 20-30WHP gains but it's not realistic to run it on the street daily cause it's riding the knock sensor like a SOB. |
07-06-2016, 04:16 PM | #22 | ||
318
Rep 516
Attached is the dyno plot he made about a year ago. Keep in mind this was with regular old RB cast wheel turbos. He ran them up to 30psi I beowiev to make 685whp. Before they were MAXED out at 550whp and would push more than 18psi at redline max WGDC because of what I described above. Brian May is the godfather of inlets on the N54 and he started the revolution he proved what they could do, many called him a liar, and then they all copied him. So yes increase of 100+whp by changing inlets and fuel/tuning is real and has been done not only by Brian but Many others with hybrid turbos. Look up any max dyno tune on hybrid turbos from 2014 back and you will see they all max out WGDC at around 550whp and won't make more than about 18psi boost in the top end. |
