AND now there's smoke...
07-05-2016, 09:40 PM | #1 |
Rep 41
I have all the mods listed in my signature, (The inlets were put on a few weeks ago) Prior to that I had the typical oil thermostat housing leak, and an oil pan gasket leak. I took the car to my local shop (2 Master BMW Techs), they fixed the leaks installed the inlets and put in Penz. 5w-40 (prior had 0w-40). And now I have white oil smell filled smoke coming out of the passenger exhaust which didn't happen before I had the car in. Happens at decel's, or boost shift (auto). If I put the car in park and let it sit for awhile I can literally fill a parking lot with smoke. If coming to a stop I put it in neutral I get no smoke. I was doing some tests with DWP (JB4 menu 10) with my son driving behind me and the lower the DWP the more smoke, the higher DWP not so much at 5000 I didn't have any smoke at idle. Those are all the details I have for this, closing on my house next so my tools are buried to research anymore. I've read every possible post out there all with slightly different symptoms. Just trying to get some other thoughts / suggestions before I go down the checklist.. Thanks for any and all help!
'07 335i AT JB4-G5-ISO - BMS DP's - BMS DCI - Meth - Cpe CP w/ Tial BOV - Walbro 450 LPFP - VRSPEED IC - Turbo Back Exhaust - - Billet Wheel RB's w/ Clipped Turbine - RB PCV - BMS OCC - 3.5 Bar Sensor - Wavetrac LSD - MHD BMS E85 Flash - RB Inlets
07-05-2016, 09:56 PM | #2 |
32
Rep 208
When did you get the turbos ? How many miles on the turbos ? I know for a fact that the billet option caused many headaches with a lot of customers. There should be some post around here if you look you will find them.
07-05-2016, 09:58 PM | #3 |
184
Rep 232
How many miles on the car? Usual culprits for smoking are the turbo seals, and sometimes a bad pcv valve. Valve seals or piston rings are less common causes.
07-05-2016, 10:00 PM | #4 |
Rep 41
Turbo's were installed a year ago April and I have around 10k on them and 120,000 on car.
07-05-2016, 11:47 PM | #5 |
153
Rep 390
07-06-2016, 11:04 PM | #8 |
32
Rep 208
April was exactly the time when the billet issues were happening weekly. I was scared as hell that my RB turbos would go at any time but it was always just the billet option that Rob had problems with. I still think pulling the dp would be a good start.
07-07-2016, 01:47 PM | #10 |
1161
Rep 3,189
