To Reuse or Not to Reuse: Flex Disc
07-05-2016, 08:48 PM | #1 |
Rep 11
I'm changing the entire driveshaft in my e92 328i. The local indy had an entire assembly purchased brand new from the dealer. He used it on a customers car for 25 miles but took it back out because it didn't fix the problem.
Should I purchase another guibo/flex disc? Or is it practically pointless to purchase a new one? |
07-05-2016, 08:50 PM | #2 |
25
Rep 116
You do not state the miles on the current one in the car. Usually they are to be considered a wear item and if you have any significant miles on the current one on the car it might be worth swapping it out while he is in there.
It also depends on what he is charging you for what is basically a used piece. But 25 miles is nothing on a new replacement.
'11 BMW///335i Sedan
Black Sapphire Metallic|Dakota Blk Lthr|Sport Seats|M Sport Sus PKG|Nav| '02 BMW ///M3Imola Red|Blk Cloth|6M|TFS CSL TUNE - MSS54HP|CSL Rep Airbox|Euro Headers|StopTech ST-40 BBKs|Kirk 4pt Bar|CF CSL Trunk|GC Race F/R Sways| |
07-05-2016, 09:31 PM | #3 |
Rep 11
the driveshaft and flex disc came together brand new, so it only has 25 miles on it.
I know mine needs to be replaced, but I guess my question is: do I keep the same flex disc with 25 miles, or do I purchase another flex disc ($60) to put on this new driveshaft I'm using to replace my old one? Basically, is the flex disc "unusable" even after immediate installation? |
07-05-2016, 09:37 PM | #4 |
90
Rep 386
Drives: 08 535xi 11 328xi
I don't see why you wouldn't use it. as along as there are no cracks in the rubber, I think it should be perfectly fine. If it was me, I would use it.
07-06-2016, 05:17 AM | #5 | |
17314
Rep 18,737
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
07-06-2016, 07:23 AM | #6 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
07-06-2016, 04:18 PM | #7 | |
Nomore
149
Rep 793
Now it depends, 328.. Use it. 335 with mods or spirited driver, might as well get the newer design part that willl flex less under load. Then just sell this basically new one... https://www.ecstuning.com/BMW-E92-33...fts/ES2500955/ They actually got rid of that design. It was standard on 2010+ production cars. And ECS was saying its an upgrade for older cars. This is the part # now https://www.ecstuning.com/BMW-E92-33...fts/ES2500947/ It seems like they made the rubber thicker.. Wonder why they switched back to all rubber after switching from rubber to aluminum. I wanted that aluminum one! It's recently been discontinued also, i was looking at it a few months ago. Planning all the parts im going to replace when i do the shifter bushings. Ordering new flex disc, and center drive shaft support for when i do it. Just install it the way it is. It came assembled new from bmw, why mess with it if it only has 25 miles on it. Last edited by AWDBooSTIn90; 07-06-2016 at 04:42 PM.. |
