Airbag light on
07-05-2016, 08:24 PM | #1 |
41
Rep 164
Airbag light on
As mentioned i was driving normally airbag light come on no crash history of the car i managed to remove the error code by MHD but sometimes it comes again .. I read somewhere of airbag recall for the same model and i checked no recall for my car as per vin number
Any help guys
BMS Dual intake system RB PCV Valve BMS Oil Catch Can BMS Oil Thermostat COBB FMIC COBB AccessPort V3 Aerodynamic kit M Package Cp-e BOV Cp-e 3" catless DP Wedge performance stg2 map
07-07-2016, 07:44 AM | #2 |
41
Rep 164
Guys anyone?
07-07-2016, 09:24 AM | #3 |
1013
Rep 1,268
There could be a number of reason you are getting the code. Any one of the components in the systems could be causing the code. You better off having the dealer look at unless you have access to system to read all the codes and interrupt what specifically is causing the code.
To give you an example Fords had a issue with the seat sensor connector. It would intermittently disconnect which would through a general code, but if you are able to read the specific reason the general code was being thrown you would know to check the seat sensor. When the code is trigger many time the system is disable so I am not sure you want to drive around with it being disable. |
