I Need Help Serpentine Belt
07-05-2016, 12:02 PM | #1 |
42
Rep 281
I had my serpentine belt just basically shred up, and my car is around 5-6 Min from my Indy. Is it safe to drive it the extra 5-6 min or to get a tow truck. I just feel out of luck because I'm so close and I don't want to damage my car if i can pay a tow truck $50 and not risk anything. But I can also save $50 and drive it if I risk nothing
07-05-2016, 12:15 PM | #2 | |
198
Rep 562
07-05-2016, 12:22 PM | #4 |
198
Rep 562
The water pump is the least of your concerns. You risk having the belt get sucked in through the crank seal. There's countless people on here who have had this happen when their belt shredded. The last thing you want to do right now is keep the engine running...
07-05-2016, 12:29 PM | #5 |
111
Rep 807
Put it to neutral and push it all the way to the indy shop if you are worried to pay $50. I would pay $100 or $200 more for peace of mind.
Garage: BMW i3 Giga World BEV | BMW E70 X5 |
07-05-2016, 01:20 PM | #6 |
78
Rep 375
If you can pull out the shredded belt and make sure none of it got into the crank seal, I honestly don't see a problem with driving it 5 minutes. You won't have power steering, and I think your battery won't be charging, but it's only 5 minutes and the battery will live.
I had a belt shred on my old E46 and I ended up driving it to the shop about 10 minutes away after just pulling it out of the engine bay. The no power steering got old really fast though. |
07-05-2016, 01:23 PM | #7 |
132
Rep 573
Mine got sucked in on my 07 so again pay the $50. Its strings from the belt that get wrapped behind the pulley imposible to get without pulling the pan and fan out i would not risk it
07-05-2016, 01:26 PM | #8 |
100
Rep 1,040
Tow truck. Unless the belt snapped clean off, you will risk sucking the shredded belt into your engine as many folks on here have done. That is a complete nightmare as you can imagine.
2009 335i M Sport coupe, BSM with black/aluminum interior, 6MT, JB4 G5, MDH Backend Flash, Walbro 255 inline LPFP, VRSF Inlets, BMS 3" catless DP's, Borla Aggressive catback, ER FMIC, ER charge pipe, Tial BOV, BMS 2.3 gal Meth Kit, BMS Sport Oil Cooler Valve, Ported CDV, RB PCV, Cyba ram air scoops, Status Gruppe SRS coilovers, ECS trailing arms, Forgestar F14 SDC.
07-05-2016, 04:57 PM | #10 |
291
Rep 2,189
If it made it into your front seal you just filled your oil pickup with rubber and started the process of starving your engine of oil.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
07-05-2016, 05:07 PM | #11 | |
25
Rep 116
Hopefully that is what you did... Most however do not... even 4 miles is enough to have trashed the bottom end bearings, both rod and crank.. along with who knows what else for the oil pump. Good luck OP
'11 BMW///335i Sedan
Black Sapphire Metallic|Dakota Blk Lthr|Sport Seats|M Sport Sus PKG|Nav| '02 BMW ///M3Imola Red|Blk Cloth|6M|TFS CSL TUNE - MSS54HP|CSL Rep Airbox|Euro Headers|StopTech ST-40 BBKs|Kirk 4pt Bar|CF CSL Trunk|GC Race F/R Sways| |
07-05-2016, 05:10 PM | #12 |
42
Rep 281
4 min not miles is what I hope you meant to say. But my local Indy said it looks like everything seems ok and I will just need to replace the serpentine belt
07-05-2016, 05:16 PM | #13 |
100
Rep 1,040
It doesn't matter if you drove it 4 feet, if shredded belt made it through the seal, you cost yourself much more than a $60 tow. Hopefully you cleared everything!
07-05-2016, 06:57 PM | #16 | |
32
Rep 269
Hopefully nothing got wrapped behind the crank pulley.. That's how it eventually gets into the engine.. Last edited by NA55; 07-05-2016 at 09:14 PM.. |
07-05-2016, 08:35 PM | #17 |
42
Rep 281
Basically yes it was 2 pieces in the end, it was an easy remove. Found out this happened because of my AC COMPRESSER stopped working. I had just installed this 1 week ago. I messaged the company I purchased it from to get a new one
07-05-2016, 08:48 PM | #19 | |
25
Rep 116
4 mins.. maybe not that bad. But damage could have been done. I interpret shredded to mean all stringy and not much really left of the belt. Sounds like that was not the case and you might have gotten really, really lucky.
