07-04-2016, 02:23 PM | #1 |
51
Rep 157
New exhaust mid back muffler remove, vibrating normal ?
Hi ive had a new exhaust on a 320d f30 two single tailpipe one each side, and muffler removed but since then I have a lot more vibration on tailpipe than runs through the exhaust, you can see the tailpipe moving when idle is this normal what's your opinions? Also the engine moves like vibrates I've not a clue is this normal ? Thanks for any help here
07-06-2016, 07:09 AM | #3 |
51
Rep 157
Propper job from custom exhaust company. I think as I've had the muffler removed obviously that is a heavey part and will not vibrate much due to its weight but now I've just got straight pipe work with tailpipe's obviously much much lighter maybe this is why I can seen the vibration more on the tailpipe? Maybe i just need more supports / hangers ?
07-07-2016, 07:51 AM | #4 |
12
Rep 53
I have seen some vibration on my F36 430d, also custom job stainless and muffler removed. But on mine I have only seen it a few times. Normally it is almost no vibration at all.
07-07-2016, 08:06 AM | #5 |
51
Rep 157
Thanks, have you got any photos of your exhaust under the car so i can compare setup ? Cheers for anyhelp,
Also mine really only vibrates when stationary idle. |
07-07-2016, 03:08 PM | #6 |
12
Rep 53
I will see if I can get some photos tomorrow or at least during the weekend. You want photos from under the car as well I guess?
07-07-2016, 03:45 PM | #7 |
51
Rep 157
07-08-2016, 05:41 AM | #8 |
12
Rep 53
07-08-2016, 06:00 AM | #9 |
51
Rep 157
07-08-2016, 09:41 AM | #11 |
51
Rep 157
Thanks its very very similar, but my rubber hangers look a lot more loose, also the metal hanger part welded to the exhaust mine is just bent down and the rubber is hooked on but yours looks like mushroom ends so the rubber and not move on the metal hanger. hope this makes sense ?>?
07-14-2016, 03:14 AM | #12 | |
12
Rep 53
08-05-2016, 10:59 AM | #13 | |
84
Rep 396
08-05-2016, 12:14 PM | #14 |
51
Rep 157
It sounds loads loads better, but I could not stop the vibration on tips its only when idle i had 4 exhaust places look at it all said the same its the way it is with some diesels as the new exhaust is also much lighter. Il try and do a vid this weekend but not getting much time at moment, what area are you ?
08-05-2016, 06:33 PM | #15 | |
84
Rep 396
