2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Tool tip, tight space leverage
      07-03-2016, 03:06 PM   #1
overcoil
3074
Drives: M235i 6spd
Was doing brake flush on a 235 front caliper with the two bleeder screws on one caliper - and the inner horizontal bleeder screw is extremely tight. Used some PB-Blaster to loosen but the 11mm socket didn't get me any movement. Saw pics a few days back of a snapped off bleeder screw, so wanted to be extra careful.
The pic below shows how to create a small extension/breaker bar for tight spaces. It provides good feel.
      07-05-2016, 04:20 PM   #2
Tpeterson
Tpeterson's Avatar
Drives: 228i MSport/THP/MT/
I saw Eric the Car Guy use that trick on his You Tube channel. Very good tip.
      07-06-2016, 11:05 AM   #3
mdputnam
mdputnam's Avatar
289
Drives: 135i & M235i Convertibles
Here's another tip: If you're going to be applying a lot of torque on the bleeder valve using a 6 point box wrench will help keep from rounding off the bleeder valve.
      07-07-2016, 01:07 PM   #4
EEBreh
123
Drives: "M" 235i
Always use a flared nut wrench when working on gas hoses and brake componentry like bleed screws or hoses.
      07-11-2016, 10:43 AM   #5
mdputnam
mdputnam's Avatar
289
Flared nut wrenches are good if you can't get the 6 point closed box end over the top of the nut. However, a six point flared nut wrench only has 5 flat surfaces as opposed to six in the closed end box. For me personally, I choose the six point closed box first and the flared nut wrench only on the tubing nuts where the closed box won't work, YMMV.
2addicts
