PSA: Bosch Front O2 Sensors for Cheap
06-30-2016, 02:20 PM | #1 |
530
Rep 2,083
If anyone is contemplating replacing their front O2/lambda sensors, the Bank 1 sensor is currently going for $83.95 w/ free shipping on Amazon.
Bosch 17098 You can use this sensor on both banks. This one has the longer wire length, so you just need to coil up the extra when you use it on Bank 2. The Bank 2 sensor (Bosch 17102) costs $140 because it's unique to the 335i.
2013 135is DCT Carbon Black Metallic |
07-03-2016, 12:38 AM | #6 |
185
Rep 890
09-22-2016, 03:42 AM | #8 |
117
Rep 143
I can confirm as just 3 weeks ago I had to replace one of my O2's. Ordered cheaper, longer cable sensor and it works flawlessly. Same connector and the same sensor, the only thing is, now both my O2 sensor cables are black
09-22-2016, 09:36 AM | #9 |
97
Rep 804
which bank o2 did you replace with this longer black cable?
E90 LCI M-sport/ 6AT/ LSD/ FBO+
11-28-2016, 08:42 PM | #12 |
530
Rep 2,083
11-28-2016, 10:08 PM | #13 |
59
Rep 425
When my turbos were burning a lot of oil, I had pre-cat lambda errors. I was about to buy new o2 sensors but waited to replace the turbos. After the turbos were replaced, no pre-cat lambda errors.
Make sure you are not burning oil before replacing the o2 sensors. This sensor will work for both banks. |
11-28-2016, 10:39 PM | #15 |
530
Rep 2,083
I'd try logging AFR and fuel trims to see if bank 2 is doing something funny.
