Who's still on their original injectors?
06-30-2016, 10:33 AM | #1 |
102
Rep 1,903
Drives: e92 335i 6MT
With all the stories of misfires and bad injectors, I want to look at things from a different perspective. I'm curious to know if certain index injectors were more reliable than others.
I will start. My car is an 02/2007 build and was not included in any of the injectors recalls. Still has index-1 injectors that it came with it and still going strong with 84k miles. Been cobb tuned for the last 49k miles. Am I an exception? I'd like to hear from others if you are still on original injectors without issues: -your build date -the index injectors you have -no of miles -any pertinent mods EDIT: Here's a summary of people still on original injectors, definitely something to be said about the early 2007 models with index 0/1 injectors: (FYI - Original injector recall was for vehicles built between 04/02/2007 through 10/31/2008) 335Junkie - 10/2006, 151k miles - (must be index 0 based on build date) Fedorov - 11/2006, 54k miles - index 0 Sgop335 - 12/2006, 93k miles - index 0 Operator Mo - 12/2006, 79.3k miles - (must be index 0 based on build date) nitehawk - 02/2007, 84k miles - index 1 Boland01 - 03/2007, 82k miles - (must be index 1 based on build date) Blaster400 - 03/2007, 26k miles - index 1 nikitino25 - 03/2007, 56k miles - (must be index 1 based on build date) V8bait - 04/2007, 84k miles - index 1? scottp999 - 04/2007, 23k miles - index 1? N0Chill 335i - 07/2007 ///Mposter - 2007 MY, 53k miles - index 1 DennisPacMo - 2007 MY - index 1 stanlalee - 2007 MY, 157k miles bizzleb109 - 2007 MY, 131k miles - index 2 1slw335 - 01/2008, 88k miles veer90 - 02/2009, 90k miles - index 7 nukezero - 05/2009, 124k miles ttribe - 06/2009, 109k miles Here's a summary of people that have changed at least some of the injectors: ritzzzzzwik - 02/2007 - Bank 1 replaced at 110k miles with index 12 (cyl 1&2 were leaking). Bank 2 are original. Neil07 - 2009 MY - 1 injector replaced at 65k miles - index 7 titium - late 2009 MY - 3 injectors replaced prior to 80k, other 3 are index 7 (one potentially leaking) idk_alex - 2010 MY - injectors changed at 75k miles BayMoWe335 - 2010 MY - injectors changed at 35k miles under warranty Last edited by nitehawk; 07-13-2016 at 06:42 PM.. |
06-30-2016, 11:02 AM | #3 |
95
Rep 951
MY2010, just got injectors replaced at 75K miles. The car always had a smoking problem, went in to get the turbos done and it was the injectors causing it.
06-30-2016, 12:22 PM | #4 |
Rep 25
Drives: 2008 E92 335xi
Stock injectors. 08 335xi 01/08 Just hit 88k miles. dont know what index because theres never been an issue with them.
06-30-2016, 12:33 PM | #5 |
406
Rep 574
April '07, factory hpfp and injectors, 84k miles tuned fbo since 18k, e85 most of it. Car doesn't qualify for the recall. Had its first water pump last weekend.
06-30-2016, 03:43 PM | #7 |
Macgyver
208
Rep 942
07 with 53,000miles index -01, and I'm not sure if they are leaking or not. I do have extra burble than normal. I might change them out when my single kit comes in.
I did ask the dealer about my 335i injector "recall" this past weekend when I had my X3 in for inspection . He looked it up and it was only showing two campaigns , turbos, and hpfp, which were completed years ago.
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
06-30-2016, 03:44 PM | #8 |
127
Rep 865
Drives: BMW X3 35i, Porsche Macan S
3/07 build with original Index-1 injectors. Only 26K miles on car. I ran FBO with RB's for a couple of years before ST upgrade last year. Injectors are still going strong.
I've considered upgrading to Index-12 injectors as preventative maintenance so this thread is very interesting to me. I think the early model year injectors had less problems than later versions.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
06-30-2016, 04:48 PM | #9 |
261
Rep 1,093
Don't know build date ect and don't want to go outside but 2007 with original injectors, 157k miles and not a single misfire or evidence of leaking or malfunctioning ever.
06-30-2016, 11:57 PM | #15 |
25
Rep 74
Drives: 2008 335i Coupe 6-speed
11/07 build
Cyl 1,2,3 are Index 12 (replaced at 107k miles after DME MOSFET and Cyl 1 Injector failure) Cyl 4,5,6 are all original Mods are in sig.
'08 E92 335i 6MT Coupe SGM | MHD Stage 2 93oct | Cp-E CP | AA BOV | DCI | VRSF DP | VRSF 5" Stepped FMIC | Apex Arc-8 | Cyba Air Scoops | Failing HPFP....
07-01-2016, 01:34 AM | #16 |
162
Rep 460
Drives: BMW 330i G20
11/06 (First gen.!) :-D
87000 kilometers. Have had the jb+, the procede "light" don't remember it's real name. Now the COBB with custom tune, not heavily tuned, about 380-390 HP according to tuner. Only real problem I've had was waterpump. |
07-01-2016, 03:13 AM | #17 | |
102
Rep 1,903
Keep the info coming guys! We should be able to make some correlation with enough data. |
07-01-2016, 06:52 AM | #18 |
406
Rep 574
This is an abnormal amount of 07 cars with factory injectors, minus the dme failure that took one. Makes me wonder if revisions were for cost cutting first, not design improvements.
07-01-2016, 06:24 PM | #20 |
160
Rep 305
07-01-2016, 11:47 PM | #22 |
1933
Rep 1,532
I have a 2007 and a smattering of -04 to -06 injectors, still going strong at just under 130k. I bought the car with 50k on it and haven't changed an injector yet. Soon....
