Sad day 335i down
06-29-2016, 04:34 PM | #1 |
10
Rep 88
Sad day 335i down
After installing the new turbos, I crank the car and started get smoke from the turbos. I hear a rattle too. The car is toasted 😔 And help? White smoke coming from the new rotor master turbo what could it be? Now I l hear a loud bang from the turbos
06-29-2016, 04:57 PM | #3 |
421
Rep 1,643
Ah!! Our very own first forum tester for the esteemed rotomaster oem turbo option....doesn't look good ....
2007 E92 335i MT
06-29-2016, 04:57 PM | #4 |
10
Rep 88
Brand new turbos I'm not quite sure it smells like coolant being burnt. Invested all this money in and once I go to fire it up, it went well for first minute, then started smoking from the turbos. I felt them and they are already hot. Not sure what went wrong.. But I purge the system before start up.
06-29-2016, 07:07 PM | #14 |
648
Rep 2,012
As per instructions on the mitsu supposed to feed 100ml or more oil in to the oil port and turn impeller by hand. I told my installer that many times.
335i e92 TPC 19Ts
06-29-2016, 07:12 PM | #15 |
10
Rep 88
06-29-2016, 10:33 PM | #16 | |
530
Rep 2,083
Also, this would not explain why you are smelling coolant.
2013 135is DCT Carbon Black Metallic |
06-29-2016, 11:14 PM | #17 |
10
Rep 88
06-30-2016, 12:17 AM | #20 |
10
Rep 88
Here's a video [u2b]https://youtu.be/AVw0mQO7tDI[/u2b]
At first it sounds good. Then it starts to become complete shit. White smoke stopped a little bit. Near the end you the banging starts Do you think the engine is still in tack? Could it be a water pump failure? Turbo mainflod get's really hot within minutes Last edited by callmehugh; 06-30-2016 at 12:35 AM.. |
06-30-2016, 01:11 AM | #21 | |
94
Rep 233
Our cars run hot as you know, so you may be overthinking the manifold heat. If your water pump wasn't running, you'd get a check engine light pretty soon I think. Just my two cents
2010 BSM 335i 6MT M-Sport w/ MMP Stage 3 Turbos
06-30-2016, 01:27 AM | #22 |
196
Rep 657
Sounds like one or both turbos are fkd. What is it with bmw and woeful stock turbo rebuild results? Makes you just want to go with someone reputable and go big single.
