Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > ATF Fluid recommendation/confirmation for GM Transmission
      06-29-2016, 10:32 AM   #1
2007E90328xi
Drives: E90328xi
Hi,
I have a 2007 E90 328Xi and am approaching 100k Miles. Already got the filter and just need to confirm which fluid to use.
Based on the research I've done, different people recommend different things.
I have used Valvoline Max life Full Synthetic on all of my other cars so far with great results. It's $20 bucks for 4 qts so the price is best out there.
It does state Dextor VI on it, which I believe is what GM transmissions use.
Has anyone used this fluid? What would you recommend?
PS. Would like to go with synthetic.
I currently have no problems with the transmission.
TIA
      06-29-2016, 11:55 AM   #2
mweisdorfer
mweisdorfer's Avatar
Drives: 2007 Black/Black 335i e90
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
Originally Posted by 2007E90328xi
Hi,
TIA
Look into Amsoil. If you buy a membership, you get 25% off all of their products.
They make every fluid for our cars except transaxle fluid. That you will have to buy from BMW or an online retailer like FCP or ECS for example. Very expensive - $45-65 for a Qt.
If your at 100k, you should do a complete fluid overhaul.
Also, change the spark plugs, coils, belts and pulleys too.
      06-29-2016, 01:40 PM   #3
zoppp
43
Drives: 2008 E60 528i
Valvoline maxlife works great in the GM transmissions. I use it in my ZF and it meets all the bmw specs. Pretty versatile fluid, no complaints.
      06-29-2016, 01:56 PM   #4
Vut
Drives: E91 LCI 328 xi
I used Red Line D6 ATF from ECSTuning.com and local store
      06-29-2016, 02:26 PM   #5
Tom Droze
413
Drives: 2012 BMW 328i (e92)
Originally Posted by 2007E90328xi View Post
Hi,
TIA
Unless you are planning on doing a complete fluid flush (not a fluid and filter change), I would suggest using the OEM BMW automatic transmission fluid. For the few bucks you might save per quart, why take a chance on mixing brands of automatic transmission fluid.
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
      06-29-2016, 02:27 PM   #6
tlow98
2188
Drives: 2009 E91, 2014 F15 x35i
Went with genuine GM stuff. No issues 11k miles after fluid/filter change.
      06-29-2016, 03:40 PM   #7
patents
164
Drives: 2008 328i
I used Dextron VI (I think it was the BMW branded fluid). It's what GM/BMW recommends, so I don't see why there's a question about what to use.
IMO GM transmissions are tough, and you will get zero benefit from using another fluid. Some people say it might feel different, but it will not make it last any longer.
      06-29-2016, 03:43 PM   #8
kkasson
Drives: 07 BMW 328i, 08 BMW 528i
Valvoline MaxLife is not actually a licensed Dexron VI fluid. It's a good fluid and Valvoline themselves claim that it will work in Dex VI applications, but it's not actually certified for it.
Valvoline does make an actual Dexron VI. That's what I used in mine and it works great. Here it is on Amazon, it's not too much more expensive than MaxLife: https://www.amazon.com/Valvoline-VV3...=1&*entries*=0
You can find the official list of licensed Dex VI fluids here: http://www.gmpowertrain.com/VehicleE...DEXRON-VI.aspx
I considered getting this one: https://www.amazon.com/Havoline-2265.../dp/B00M1Y3KZA but it was out of stock when I was buying my fluid. It's also officially licensed so it should work fine, and it's definitely the least expensive you'll find.
      06-29-2016, 11:38 PM   #9
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Redline D4.
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
      06-30-2016, 02:02 AM   #10
kkasson
Originally Posted by Cory S View Post
Redline D4.
If you're gonna go with Red Line, at least use D6. It also isn't a licensed product, but everyone has their own opinions about the "boutique" oils. A lot of people seem to use Red Line without any problems so I'm not saying that it won't work, just pointing out that it isn't officially licensed.
However Red Line itself doesn't even claim that D4 is suitable for the 6L45, so go for the D6 if you want Red Line.
      06-30-2016, 02:06 AM   #11
kkasson
For anyone else that might be looking for differential fluid, my local BMW motorcycle dealership had it way cheaper than the car dealership. They sell it as Final Drive Gear Oil, but it's the same SAF-XO as the differential oil. It was something like $20/liter instead of $50 at the car dealership.
      06-30-2016, 02:38 AM   #12
F22_Raptor
F22_Raptor's Avatar
Drives: 2008 328i
I haven't changed my AT fluid yet but i plan to use AC Delco Dexron VI.
https://www.amazon.com/gp/product/B0...A3MA0GVAOHQZNN
      06-30-2016, 05:01 AM   #13
Cory S
Cory S's Avatar
Drives: 2011 335i-X
Actually it does. For my ZF in my 335..
