Outer tie rod stuck
06-28-2016, 08:40 PM | #1 |
10
Rep 88
Outer tie rod stuck
06-29-2016, 09:10 AM | #2 |
41
Rep 160
You should have cracked the inner rie rod from the outer tie rod end when the outer was still bolted to the knuckle. Bolt the outer back into the knuckle, crack it free, and the unbolt the outer and spin it off. Its most likely siezed on there, so youll need the leverage
07-03-2016, 02:15 PM | #3 |
255
Rep 494
Just replace the whole thing - the inner and outer tie rods as a unit. The inner will unscrew from the steering rack. I had a similar situation on my e90. It was actually pretty easy to do.
2016 F80 M3 (Mineral/Full SO)
2014 X5 M Sport (Mineral/Mocha) |
