06-27-2016, 09:36 PM | #1 |
426
Rep 346
Stock BMW M2 Hub dyno 342whp - 491Nm
More than I'd expected to be honest. About the same as the e9x M3 but with a boatload more torque across the rev range. With an assumed 15% drive train loss, that means 393hp and 564Nm (!!!) at the crank. Approximately 164Nm more than the e9x. Very consistent over 6 runs as well, which speaks well of the stock cooling system.
06-28-2016, 12:43 AM | #3 |
426
Rep 346
Don't know for sure, but I've seen this same car use launch control so should be out of the break in period. Only around 10,000km on the clock though, I believe.
06-28-2016, 03:16 AM | #4 |
211
Rep 216
Below is the dyno result from a 2007 M3, made on the same type of Rototest dyno in Sweden.
http://rototest-research.eu/popup/pe...p?ChartsID=768 There is an extensive list of cars dyno results to compare it to here: http://rototest-research.eu/index.php?DN=29 Br |
06-28-2016, 03:21 AM | #5 | |
211
Rep 216
Nice find Itīs quite impressive the wheel torque is almost on par with the 522nm the C63 AMG putīs down to the wheels http://rototest-research.eu/popup/pe...p?ChartsID=795 Very impressive numbers! Br |
