tuning help needed with jb4 and vrsf 3" catless dp's
06-27-2016, 07:08 PM | #1 |
Rep 6
Hello all. This is my first post as I'm new to tuning and trying to learn as I go along. I've had the jb4 with BMS DCI's installed and running good for about 4 months or so. No codes or headaches, just pleasure! I always use map 5 because I'm not sure if map 1 and 2 would be safe with the 91 octane we have here in California....
Spring forward to this last Saturday, I installed my new VRSF 3" catless dp's myself with the help of a video from the guy's over at AR. Drove about 200 miles on them so far (still in map 5) and today I got the service engine soon light on the way home from work. I was just cruising on the freeway around 75mph when I noticed it. The car seemed to bog a bit at low rpms. Got home and instantly got the codes off with the jb4. 2D2E Angle of throttle valve - intake pipe underpressure, correlation 2A17 DMTL diagnosis module tank leakage, system failure 29F4 Catless Downpipes Detected 29F5 Catless Downpipes Detected I'm not real sure what I should do from here and would greatly appreciate any advice! Thanks |
06-27-2016, 08:58 PM | #3 |
25
Rep 193
+1 the two catless DP codes are shadow codes and dont need to be worried about. As for the other two, do a quick search for BMW e90 08 codes and there are plenty of threads on N54 tech that resolve these issues.
06-27-2016, 09:08 PM | #4 | |
406
Rep 574
Also, backend flash. I'll get you started. |
06-27-2016, 10:45 PM | #5 | |
Rep 6
I just took the car for a drive and upon initial take off, I was getting a good amount of smoke out of the tail pipes but no codes.(smelled like fuel). Once I started going though the smoke stopped. I had the Hpfp replaced right before I installed the jb4. I'm thinking I should change my jb4 user settings back to default and let it relearn the car? |
06-27-2016, 10:49 PM | #6 |
Rep 6
Thank you. Yea I was expecting the dp codes but the other two kind of scared me. I found that for the intake code, resetting it may just do the trick. If not, setting the jb4 user settings back to default hopefully fixes it.
06-27-2016, 11:35 PM | #7 | |
25
Rep 193
As for the reset, no real point. You could do a 1/7 reset through the steering wheel options on the JB4. |
06-27-2016, 11:38 PM | #8 | |
Rep 6
06-27-2016, 11:49 PM | #9 |
25
Rep 193
Im from Australia so I use 98RON fuel which (correct me if I'm wrong) equates to around 93 octance. But running map 2 on 91 octane is fine. If you're still hesitant, run on map 5 first and see how you like that.
06-27-2016, 11:58 PM | #10 |
Rep 6
I've been on map 5 since I first got the box and intakes, but the thought of it constantly retuning kind of erks me. I know others do it just fine but a more consistent tune would make me feel better. I wish we had 93!
Tags |
2a17, 2d2e, jb4, vrsf 3" downpipes |
