Car died mid corner sent me off the track.
06-27-2016, 01:34 AM | #1 |
69
Rep 534
Update: Car Spun 4 Rod Bearings, pics on page 3.
I was at the track this past weekend and during a rather high speed bend the car completely shut off at corner entry. As a result the back end stepped out on me and I had to bail into the grass. Vid here https://www.youtube.com/watch?v=JH9ffdUt4p4 After I had the wrecker tow me back to the paddock I pulled the following codes: 2E8D 2A82 3100 The car would not fire up, no clicking or any signs that it was attempting to turn over. I did find significant moisture in the battery housing area(water bottle got lodged back there and cracked). Disconnected the battery and cleaned everything up and re-connect the battery. Now it displays a new set of codes which are as follows: 2ACC 2D1D Now when I try and start it there's a click and it everything cuts out. I've tried jumping the car with another vehicle but still no dice. Any input is appreciated.
Frozen Black Widebody E92 : VRSF CP, N54Tuning Downpipes, Tial BOV, DCI, MHD Flash, Aquamist HSF-3 Meth kit Dual Nozzle, Megan Racing Toe Arms,Megan Racing Camber Arm, Megan Racing Trailing Arm, IND Delrin Subframe Bushings, M3 Control Arms,Fortune 500 Series Coilovers, Square 18x11 Apex Ec7 w/ 315/30/18 Hoosier R7's
06-27-2016, 08:54 AM | #2 |
Roll Tide
591
Rep 2,345
2E8D:
2E8D Intelligent battery sensor, signal transmission Short circuit or signal interruption 2A82 and 3100 are VANOS related codes, have seen those go away with an oil change. You were probably stressing the oil pump, and if not using the right viscosity for a track day in the desert the VANOS may have gotten starved. 2ACC: 2ACC DME digital motor electronics main relay, switch delay 2D1D Accelerator pedal module, pedal sensor 1, voltage supply Throw a couple of packs of desiccant in the battery area to absorb any moisture and put it on a charger. |
06-27-2016, 09:53 AM | #3 |
69
Rep 534
Odd, I was running Rotella 5w40 like I always do. Actually had the oil changed the day before the event.
Currently, when I try and turn the vehicle over it will click and turn off as if there is a battery cable loose but the cables are secured in the rear. This also happens when I tried to jump start it using another vehicle. |
06-27-2016, 12:17 PM | #4 |
Resident old fart
146
Rep 575
When you experience a major electrical malfunction that causes wild voltage fluctuations, I would not take any minor codes seriously unless they return after the main problem is resolved. A sensor will not return the correct voltage when the input voltage is wrong. I have seen cars with alternator problems (or dead batteries) flag strange codes that do not return when the alternator is replaced.
06-27-2016, 12:38 PM | #5 |
69
Rep 534
The battery is shot so ill start by replacing that.
06-27-2016, 01:23 PM | #6 | |
197
Rep 1,070
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
06-27-2016, 01:35 PM | #7 |
69
Rep 534
i cleared all the codes after reading them initially. Removed the battery and put it on a charger for a while. Cleaned the battery tray and removed the moisture. Plugged everything back in and the 2ACC and 2D1D codes popped up. But instead of the car doing nothing when i hit the Start/Stop buttons it makes a click noise and cuts out as if one of the battery cables is loose.
06-27-2016, 01:51 PM | #8 | |
57
Rep 272
FBO , MHD , tuned
06-27-2016, 05:30 PM | #10 |
122
Rep 397
You may want to review this thread about a bad main power connection to the fuse box.
http://www.e90post.com/forums/showthread.php?t=566291 |
06-27-2016, 05:36 PM | #11 |
261
Rep 1,093
Mine acted similar when my alternator went out (over the course of two days). Wasn't a cheap fix at the dealer either. Dealer told me when it goes often wipes out there battery too but mine survived.
06-27-2016, 09:44 PM | #12 |
48
Rep 270
Double check your BST. It'll give you power to everything except to crank up the car. Designed for accidents to prevent the car from igniting.
06-28-2016, 08:11 AM | #15 |
187
Rep 670
Am I the only person that noticed he's blasting Highway to the Danger Zone on the track?
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
06-28-2016, 08:15 AM | #16 |
2032
Rep 8,339
07-03-2016, 02:41 PM | #17 | |
255
Rep 494
2016 F80 M3 (Mineral/Full SO)
2014 X5 M Sport (Mineral/Mocha) |
07-05-2016, 01:19 PM | #18 |
69
Rep 534
haven't had time to really dig into the car but I wanted to ask you guys what you think caused the car to die all of a sudden? I would hate to put the new fuses and relays into the car just for it to die at the track again.
Sitting in a hot car that's low to the ground in tall dead brush is not something I want to relive lol. Not to mention those two sessions I got were the most expensive two sessions of my life lol.
07-05-2016, 05:34 PM | #19 | |
75
Rep 630
Drives: '09 335 E93 6MT
What added electronics do you have connected? It could be as simple as an overloaded circuit while on the track
Convertible | Manual | M-Sport | MHD Stage 1 + FMIC | 335is Clutch | ER CP | RB Inlets | VRSF 5" Stepped FMIC | M3 F/R Control Arms | KW V3 | Hawk HPS Pads | Stoptech Slotted Rotors | Blackvue DR650-2CH Dash Cam | LCI Taillights
07-05-2016, 07:33 PM | #20 | |
295
Rep 2,202
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
09-16-2016, 11:35 AM | #21 | |
69
Rep 534
I even tried a Spare DME CAS and keys to see if I had fried the DME somehow but the result was the same. I did scan the car with INPA and can post those codes as well.
10-31-2016, 01:10 PM | #22 |
69
Rep 534
Update:
Per the recommendation of a couple of my friends I tried to Spin the motor manually and it will not budge. Looks like the problem appears to be mechanical and not electrical (Thank god... i think?). I'll keep everyone updated on what failed.
Bimmer 808170.00 |
