Help on Part Number Needed
06-26-2016, 07:32 PM | #1 |
83
Rep 353
Hi,
I have a 2009 335i xdrive coupe. I took the panel on the front passenger door to replace the wiring harness and in the process broke the connector as shown below. As you can see the pin connectors broke and the white plug. Anyone knows what are the part numbers. I searched but couldn't find what is it. I need to fix it so I can put back the door panel. I don't even know what it is for The above gets connected to the below Any help on this is greatly appreciated Thanks RB
15 F06 640i xDrive Gran Coupe/Grey
06-26-2016, 08:10 PM | #2 |
1007
Rep 2,109
The part number is on the sticker in your pictures 9122419
Here is realoem http://www.realoem.com/bmw/enUS/partxref?q=9122419 Here is ecs https://www.ecstuning.com/Search/63319122419/ES175569/ If you just want the connector and pins you may find them at realoem, there is some section like various connectors from what I remember but it wouldn't be easy to find the exact match. A visit to dealer may help to get just the connector, if they sell it that is separately. |
06-27-2016, 05:00 AM | #3 |
83
Rep 353
Thank you.....any idea how to remove the clear tube from the black connector and how do even remove the black connector if I go and replace the whole thing
I was under the impression its one piece. I m trying not to break anything else. I was going the easy route to just get the connector and the pins. But if I can swap the whole thing I would but need some guidance on how to remove it Thanks |
06-27-2016, 10:16 PM | #4 |
1007
Rep 2,109
Try this one, from pictures looks like a fit, even though different color:
https://www.ecstuning.com/Search/Sit...043/ES2848565/ |
