Four Error Codes - Need Help Please
06-24-2016, 01:52 PM | #1 |
22
Rep 84
Evening all,
Got 4 codes come up. Not sure what the first 2 are, any ideas? <===========================> 0. Motor Control: <---------------------------> Engine / Motor: - Fault: Message (GESCHWINDIGKEIT_RAD, 0xCE) - Code: 0049F2 - Fault: Motorabstellzeitermittlung - Code: 004DFB <===========================> 1. ABS / DSC / Brake: <---------------------------> Dynamische Stabilitaets Kontrolle / DSC: - Fault: Speed sensor rear left - Code: 005DB1 - Fault: left rear direction detection - Code: 005DB6 <===========================> Cheers, Ryan |
06-24-2016, 03:15 PM | #2 |
187
Rep 1,247
You've got a dicky left rear wheel speed sensor or potentially a swollen reluctor ring.
That will fix faults 1, 3 & 4. No 2 looks like the High Pressure Fuel Pump; http://www.bmwforums.info/bmw-3-series-forum/16332-**fixed**fuel-rail-pressure-regulating-valve-e90-lci-325d-2010-a-3.html |
06-24-2016, 04:04 PM | #3 |
22
Rep 84
Thanks mate.
I REALLY hope it's not the HPFP. Saying that, the car is a little lumpy for a few mins on startup. Is that normal for the N57 diesel lumps? Speed sensor is a cheap and easy fix so will get that sorted and then scan the car again. On the first scan, the 4DFB code didn't show up... |
06-25-2016, 03:50 AM | #5 | |
187
Rep 1,247
It was lumpy on idle when I bought it but that was 4 dead glow plugs but you don't have codes for glow plug faults. |
06-25-2016, 06:24 AM | #6 |
22
Rep 84
Still a tiny bit lumpy this morning but only on initial start up. I can drive 20 yards and stop and it's fine?
The 4DFB code didn't pop up today but the other speed sensor related ones did.
2010 E90 LCI 325d
06-25-2016, 07:13 AM | #7 |
187
Rep 1,247
What diagnostic tool are you using?
I'd suggest getting a copy of Rheingold if you don't already have it as it can do some clever stuff. There may be options to reset the fuel pump etc. |
06-25-2016, 08:50 AM | #9 | |
187
Rep 1,247
Get a K+D-Can cable and this will get you a working version of Rheingold. Google rutracker Rheingold 3.47.10. That is a fully working version of the software. There are newer versions but they require an earlier version such as this to install. To install; Google car technology 3.44 and firstly follow the instructions on here to install. Then use the instructions in the configuration manual that came with the download to finish it off. It sounds complex but it's pretty straightforward if you follow the instructions step by step. |
