Stock OE turbos are cheap! $558 mitsubishi vs. $657 genuine bmw
06-10-2016, 01:31 PM | #1 |
346
Rep 1,465
So my car is at the shop and I saw my mechanic guy pull up his computer to give me pricing on the car. He tells me he has two sources. One is direct from the dealership (Crevier BMW in Orange county) and the other is a OE supplier.
He said both turbos should be the same just one is branded BMW genuine and the other is Mitsubishi. The Genuine BMW one was $657 and the Mitsubishi OE one was $558 each. He asked me which one I wanted. It's a $100 difference and does it make sense to get the genuine one? I never knew turbos were this cheap but clearly, anybody in the US should be able to get their turbos replaced for under $2500. Add $200 for miscellaneous hardware kit. The shop is charging me $1200 for labor. So keep this in mind guys, don't get ripped off! I don't see why we're paying nearly 3-4X more for aftermarket turbos that don't even last half as long. |
06-10-2016, 01:37 PM | #2 | |
380
Rep 1,497
If u plan on staying fbo and are okay with that sure, but being fbo your turbos won't last as long as a bone stock car with 8psi will |
06-10-2016, 01:38 PM | #3 |
48
Rep 270
I believe you get what you pay for. The "aftermarket" ones are typically built to withstand a beating especially if they're made for high rpms/heat and what not. The OEM ones are made to last the life of the vehicle, just my .02
06-10-2016, 01:46 PM | #4 |
232
Rep 723
Well OEM units are made by Mitsubishi. But if you're not sure, get the BMW branded. I know there are quite a few aftermarket options available that are supposed to last long and be better, but the horror stories made me put another set of OEM units. If you're not planning to go much beyond 400whp OEMs are fine. Depends on what your goals are
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
06-10-2016, 03:58 PM | #5 |
381
Rep 910
conrad325i11.50 |
06-10-2016, 10:07 PM | #6 |
2897
Rep 3,729
conrad325i11.50 |
06-10-2016, 10:53 PM | #8 |
100
Rep 1,040
Misubishi are OEM, just not stamped with "BMW." The difference may lie in the warrant. Also, see if there is a core charge for the BMW ones, there most likely is. Absolutely zero difference in quality. TD03/04 are JDM snails!
06-11-2016, 10:52 AM | #9 |
421
Rep 1,643
Not sure what the warranty is on the mitsu branded, but the Bmw branded should come with 2 year parts warranty. This means if they break, any Bmw dealer should cover the cost of the part and the cost of labor to replace the failed Bmw part.
2007 E92 335i MT
06-12-2016, 05:03 PM | #11 | |
20
Rep 352
06-12-2016, 05:46 PM | #12 | |
261
Rep 1,093
These turbos ARE OEM turbos. There are no other application for these (whole assembly) and they are the OEM supplier. No different then buying TRW M3 control arms. |
06-12-2016, 06:31 PM | #13 | |
381
Rep 910
06-12-2016, 06:35 PM | #14 |
381
Rep 910
06-13-2016, 06:07 PM | #15 |
346
Rep 1,465
Yeah, TisherBMW has the $650 price for each OEM turbo which is pretty darn good already. But if you guys try to talk to your local mechanic, he might have wholesale pricing and can get you the Mitubishi OEM ones for like $560 each. I don't know who the supplier is for my mechanic guy. But I know he uses some online database.
06-14-2016, 08:05 AM | #16 |
43
Rep 301
i found a source for the Mitsubishi turbos at $589. GPS sells them. I just want to clarify how to tell if the turbos have the latest wastegate assembly. Is there a date code after which point Mitsubishi upgraded the wastegate? The rep said the part has been superceded multiple times but does not know how to confirm the wastegate assembly. Someone have a picture of the build date location?
06-14-2016, 08:47 AM | #17 |
3441
Rep 79,211
Likely no different between Mitsubishi or BMW since Mitsubishi is the manufacturer.
The question comes down to warranty and being the latest design. |
05-15-2018, 01:57 PM | #20 |
12
Rep 162
| H&R Coilovers |ApexArc-8s| M3 ControlArms | RogueTransMounts | AFEDualCone | ERChargePipe | TialBOV | ETSIntercooler | 335isClutch | BMSCatchCan | UUC EVO3 SSK | MichelinPSS | CobbAP | JB4 |
05-15-2018, 01:58 PM | #21 |
12
Rep 162
$1,600 each hahaha
