Value of M-Sport suspension
06-08-2016, 05:48 PM | #1 |
77
Rep 330
Trying not to screw a fellow member, and also trying not to pay more than appropriate. Can anyone chime in on what a good offer would be for a used m-sport suspension with 54k miles? Please pm if you don't think discussing numbers openly is ok
06-08-2016, 06:02 PM | #2 |
419
Rep 656
I recently sold the BMW Performance Suspension with yellow springs, no front M3 sway bar, for $370. It had about 23k miles on it. That would be an upgrade from the M Sport suspension.
06-09-2016, 06:40 AM | #4 |
674
Rep 740
For a worn-out Msport? I don't know that I would drive across town to pick up a free one.
By 50k, it's time to replace the shocks, so they have no value. Springs will still be ok, but unless you need replacement springs they won't be worth the effort to install. If you're repairing damage on the cheap, they're ok - but cost should be in the range of a six-pack or two. If you're looking for drop or better performance look for Koni or Bilstein Spring/shock combos, or coilovers. |
06-09-2016, 06:43 AM | #5 | |
77
Rep 330
06-09-2016, 08:57 AM | #6 | |
2134
Rep 3,554
Like others mentioned, it is barely worth the time to pick up and install. For a reference, you can get a complete sport suspension upgrade kit new from ECS for $950, and it is an upgrade over the OEM sport suspension. Figure Half that price for OEM, and then take off 75% or so for the amount of mileage. |
06-09-2016, 09:40 AM | #8 | |
2134
Rep 3,554
FWIW, there have been plenty of people that have had components fail at or before the 50k mile mark. Why risk it? |
06-09-2016, 09:55 AM | #9 | ||
77
Rep 330
06-09-2016, 10:04 AM | #10 |
Slow.
3782
Rep 7,151
Drives: Single Turbo N54 on Meth!
I would say $200-400 but only for someone who wanted to return their car to stock to sell it depends on their time frame.
For the labor involved it is not worth it and it really isn't an upgrade.
06-09-2016, 10:27 AM | #11 |
708
Rep 2,606
Drives: 06 330i E90, 18 530xe G30
Call your local indy shop and ask him what it would cost to do a full suspension install. It might help put things into perspective. Its not an easy job, I would guess it is in the 600 dollar range. I went with Koni yellows and pro-kit springs and my car has the perfect stance. All the raked pictures seem to have install issues causing this.
06-09-2016, 10:28 AM | #12 | |
77
Rep 330
06-09-2016, 10:34 AM | #13 |
340
Rep 922
What's the purpose of buying the M-sport suspension used vs. buying any other suspension upgrades? You stand to gain nothing by putting worn suspension components on your car.
If your desire is to keep everything OEM, order OEM M-sport suspension online or from the dealer-- you won't like the price, but it won't be used. If you want a suspension refresh and lower ride height, take a look at the aftermarket options. Again, won't be cheap, but it won't be used up by the time you get it installed on your car. If you just want to lower your car for as little money as possible... Don't do anything. Leave it the way it is. Suspension is not the place to cut corners. Max
2006 330i 6MT Jet Black / Black
06-09-2016, 10:43 AM | #14 | |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
imo for local pickup: If from a good location (smooth roads, no potholes, no salt to rust), might go another 54k miles. If this were the case, a complete set of dampers could be as much as $100-150...but sellers may settle for less. New Bilstein b4 dampers are around $350 shipped. Springs might fetch $50-75 to a patient seller. Shipping costs always muck up the pricing. |
06-09-2016, 10:47 AM | #15 | |
77
Rep 330
06-09-2016, 12:23 PM | #16 | |
340
Rep 922
Refreshing the suspension is a noble goal but might not be as necessary as you think. Might be worth it to have an indy put it on a lift and tell you if they feel it needs a refresh. My E90 with sport pkg has 120K on the original suspension and a shop recently told me it doesn't need any suspension work. I was surprised that it's holding up so well. You could drive yourself crazy shopping for upgrades on these cars, which you alluded to with the custom shocks. Every upgrade/mod will be a compromise, but I think the coilovers will provide the desired effect of lowering the car with minimal inconvenience to you. Hope this helps! Max
06-10-2016, 07:36 AM | #18 | |
77
Rep 330
06-10-2016, 09:40 AM | #19 |
66
Rep 675
06-10-2016, 09:45 AM | #20 | |
77
Rep 330
06-10-2016, 09:49 AM | #21 |
66
Rep 675
If your looking for a good shock spring combo check out the suspension section. Koni orange and Eibach springs come as a kit for $600ish. Anyway a search in the suspension section will steer you in the right direction
