06-06-2016, 07:58 PM | #1 |
26
Rep 151
Code Seats To Move Back...
I am trying to code to get seat to move back when engine is off and forward again when I start car....
I have a 2016 M235i got 2 weeks ago. When I was trying to code below, : SM2 -> 3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C I don't have Modus_FA_SLV as an option to choose |
06-06-2016, 09:20 PM | #5 |
922
Rep 5,538
06-27-2016, 11:37 AM | #9 |
625
Rep 1,753
Also keep in mind that if your driving position is too far back the default values won't work. There's a safety feature that won't let the chair go back too far.
That said, can someone translate what the movement settings are? I had to bump my driving position forward a tiny bit in order to get the defaults to work.
06-27-2016, 12:33 PM | #10 | |
35
Rep 174
SM2 -> 3012 EAH -> EAH_VERFAHRWEG_SLV_PHYS = Werte=00, 28 [this is the amount in mm the seat moves back] SM2-> 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C [This is the amount in mm from the back stop it allows the seat to move back; to leave room for the rear passenger] You'll probably have to increase the EAH_VERFAHRWEG_SLV_PHYS amount but also decrease the EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS value ***Someone else, that has changed these values, could confirm my suggestion as it is only a suggestion as it works on the default settings for me*** |
06-30-2016, 05:52 PM | #11 |
58
Rep 227
For me just changing:
3000 SM_GLOBAL -> EINAUSSTIEGSHILFE = Modus_FA_SLV 3012 EAH -> EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte=00, 3C Worked perfect. With only the first change it did not work in my normal driving position (further back, I have long legs).
Current
19' G05 X5 40i 03' e46 M3 Convert. Past09' e90 335d, 11' E70 X5d, 16' F22 M235xi |
07-06-2016, 11:01 AM | #14 |
60
Rep 273
Doesn't this feature make it a bit tricky to start the car? If you're too far back, holding the brake can get tricky...
//M235ix Alpine White
bluesman826646.00 |
07-06-2016, 11:25 AM | #15 |
58
Rep 227
Not at all for me, you definitely feel further back but I can still reach all the controls fine. Its not THAT much of a difference.
Current
07-06-2016, 02:54 PM | #16 |
625
Rep 1,753
If you close the door and press the start button the seat will move forward. I always put my car into sport+ before I start the car, so it's just part of my "launch sequence".
07-18-2016, 02:53 AM | #17 |
2374
Rep 8,364
12-21-2019, 11:50 PM | #18 | |
70
Rep 56
Hello all, anyone know the up and down seats setting coding how to do?
KenHo Macao S.A.R.
12-22-2019, 09:39 PM | #19 |
46
Rep 85
I've definitely got that problem. I have to hold on to the steering wheel and push the brake, which sometimes messes up the seat trying to move forward. I then have to push the side button to get it in my position. I know you can have it not go back so far but unless I see the exact steps for bimmercode.
