M2 Technical Topics > Suspension | Brakes | Chassis > Turbine Deceleration Noise while Braking
      06-01-2016, 02:42 PM   #1
LinkF1
Drives: 16' MG F87 M2
I have less than 50 miles on the car and have a loud and somewhat disconcerning noise coming from the brakes that gets louder as the car slows. It sounds like a jet engine or turbine throttling down. I did some quick research and found this thread from our M3/M4 brethern with the same issue:
http://f80.bimmerpost.com/forums/sho....php?t=1033297
The sound is perfectly portrayed in the video in the second post of that thread around the 6:15-6:25 timeframe. I think it is caused by the pattern on the surface of the brake rotors, as seen in this picture:
http://f87.bimmerpost.com/goodiesfor...80_highRes.jpg
Apparently this sound goes away as you drive the car more and more, but to be safe, I am ensuring the brakes are bedded in properly. If you need tips on how to bed brakes tire rack has a few recommendations: http://www.tirerack.com/brakes/tech/....jsp?techid=85
      06-02-2016, 12:21 AM   #2
HP Autosport
BimmerPost Supporting Vendor
Drives: F80 M3
Will likely go away after a proper bed-in.
      06-02-2016, 09:04 PM   #3
LinkF1
Over 100 miles in now, the sound is much less pronounced, bedding the brakes seemed to help immensely.
      06-02-2016, 10:15 PM   #4
HP Autosport
Drives: F80 M3
Some people also experience this with new BBK's with slotted or drilled discs.
      06-02-2016, 11:44 PM   #5
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Mine sounds exactly the same.
      06-03-2016, 04:01 AM   #6
MR.
MR.'s Avatar
4398
Drives: BMW M2 CSL Turbomeister
Same here, it was gone after 200 KM
MR
      06-03-2016, 05:16 AM   #7
Robin_NL
S0THPAW
Robin_NL's Avatar
8710
Drives: HS M2 Competition
Same turbine like noise here. Will go away after a few 100 miles and brakes are bedded in. I did a 'full stop from 90-0' wednesday evening and I think the brakes now know who they have to deal with the first oncoming years
Cheers
Robin
Search this Thread:
Advanced Search
m2
