My Forgestar F14s SDC journey
06-01-2016, 01:28 PM | #1 |
148
Rep 208
From my research I don't think anyone has ever shared their journey from beginning to end when buying their Forgestars so why not me do it. I have an 07 E90 335I and bought 19x9.5 fronts and 19x11 rears. Ordered on 04/25/2016 and should be done first or second week of June (fingers crossed). And if anyone is wondering - the total cost including tires, installation and fender rolling is about $3,000. Will update this thread as needed.
06-01-2016, 01:59 PM | #2 |
453
Rep 2,973
From someone that went down the Forgestar rat hole. Don't ever bend or crack a wheel.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
06-01-2016, 02:38 PM | #3 |
148
Rep 208
06-01-2016, 05:26 PM | #4 | |
453
Rep 2,973
I owned by F14s for a little over a year. I bent/cracked one of my front wheels and cracked both rears. Forgestar wouldn't help out at all. They wanted me to pay full retail for replacements. I replaced them with Apex wheels. They stock the wheels I bought. They weigh a little more than the Forgestar wheels but are designed stronger outside and near the bead area. They are less likely to crack/bend and Apex will also discount a replacement. The limitation is that you have to live with the color and offset. Not a big deal for me. But is you want to run something crazy, you can't get Apex. The only reason I didn't buy Apex from day one, is that they didn't have a 19" wheels at the time. Anyway, good luck and may you always have smooth roads..
06-01-2016, 06:12 PM | #5 |
232
Rep 642
Drives: 2010 E92 335i
Depending on how low you are (or how low you want to be), you may need to get other suspension components such as camber plates/arms, and toe arms.
06-02-2016, 01:24 PM | #6 |
38
Rep 243
Drives: 2018 M3
SDC's are a mother to fit too. I spent atleast a month making adjustments to not rub. I ended up shaving down the front fender brackets to basically nothing and the rear ones too haha.
06-03-2016, 11:02 AM | #7 | |
148
Rep 208
What tire sizes did you end up going with? I am really looking to get as much meat on the tires as possible. |
06-03-2016, 01:45 PM | #8 |
682
Rep 1,155
you will not be able to run a meaty setup with SDC all around. you'll also probably have to be lowered and have camber plates.
06-03-2016, 07:45 PM | #9 |
223
Rep 5,120
Ive had my F14's for 2 years with BC coils 10k 16k springs and the shocks set almost as stiff as they go. My wheels take a beating daily driving on bad roads. I didnt have any bends or cracks when I got new tires a few months ago. With 9.5et22 in the front I had 245/35/19 -1.7 camber and the fenders flattened. Now I went down to 235 so I can take a little bit of camber out. In the back I have 11"et33 275/30/19 -2 camber and I use a 5mm spacer when I don't have any passengers in the back. My rear fenders were rolled and I shaved some of the fender by the rear bumper. Next set of tires I think I will do 225/35 and 265/30 to take some camber out.
I had a set of Avant Garde m310s when I had my stock suspension and after a few years I had some minor bends on the wheel lips and one wheel had a larger bend which caused a vibration. Not saying Forgestar makes the best wheels but they've held up for me and I got my wheels less than 3 weeks after I ordered. Last edited by bmw325i; 06-03-2016 at 07:57 PM.. |
06-03-2016, 07:57 PM | #10 |
38
Rep 243
Drives: 2018 M3
I ran 235/35/19 up front and 265/30/19 in the rear. Ride quality was ehhh here in New England and I literally cringed every time I hit a bump in the road =(
06-04-2016, 12:37 AM | #11 | |
148
Rep 208
Oh wow, I just researched and saw your car on other threads. The Forgestars on your car looked awesome. I also saw your post about selling your Forgestars because you moved from CA to MA. What a bummer. |
06-04-2016, 12:42 AM | #12 |
148
Rep 208
What you know, today it got moved to the next stage. Not really sure why these wheels take 2 months to be made but can't complain though because I knew that going in.
06-04-2016, 01:08 AM | #13 | |
148
Rep 208
After all the informative input on this thread I am beginning to actually like the 235/265 look very much. |
06-04-2016, 08:15 AM | #14 |
682
Rep 1,155
265 is plenty of tire. im about to drop down to a 225 front 255 rear.
06-12-2016, 02:42 PM | #16 | |
223
Rep 5,120
The rear tires seem like they wear out faster on the inside. I think my toe is off from hitting bumps and driving on bad roads for the last 2 years. When I get an alignment I will try -1.5 front and -1.7 rear. After my rear fenders were rolled I used a bandfile sander from harbor freight to taper down the fender where it meets the bumper. That is the area where I had the least clearance. If you go with a 265 it will be less work to make them fit. |
07-08-2016, 08:27 PM | #18 |
148
Rep 208
So, the wheels have moved to the completed stage and are ready to ship. Pat @ Sonic Tuning has been very good at giving updates. There was one delay because one of the wheels wasn't right and had to be re-done. All in all it took about 10 weeks (which I am not complaining because I knew that time frame going in).
Now the question, I am really looking to fit as meatier tires as possible and in speaking with my shop guy he says that if I put on coilovers I would be able to. Did I understand him right? Not looking to spend a fortune on coilovers, would $700 buy me a good quality set of coilovers? |
07-11-2016, 04:34 PM | #19 |
682
Rep 1,155
spend 1000 and get bc if you are on a budget. bc is everything you need and they are a good price.
07-11-2016, 11:14 PM | #20 |
148
Rep 208
07-12-2016, 08:07 AM | #21 |
682
Rep 1,155
you have more space than I do (e92). im running 235/35 265/30. you should be able to size up very easily. 245 and 275. maybe a few e90 guys will chime in and give you more help.
