06-01-2016, 12:54 PM | #2 |
63
Rep 128
Typically you want to be around 38-40 hot (start around 30-32 cold)depending on the tires. Some require more heat others less, this information is usually available from the tire manufacturer.
06-01-2016, 12:59 PM | #3 |
29
Rep 34
Here are some pretty good values from the german Sportauto test (translated by me, so pls. be patient):
"Instead of the recommended warm tire pressure of 2,2 bar for all wheels for Hockenheim the recommended tire pressure for the Nordschleife is 2,5 bar warm for front tires and 2,0 bar warm for rear tires" For the non Europeans : - Hockenheim : GP track with perfect surface - Nordschleife : well, you should now that - 2,0 bar ~ 29 psi - 2,2 bar ~ 32 psi - 2,5 bar ~ 36 psi (german original) "Statt des für Hockenheim empfohlenen Warmluftdrucks von 2,2 bar rundum wird für die Nordschleife ein Luftdruck von 2,5 bar warm an der Vorderachse und 2,0 bar warm an der Hinterachse empfohlen." This information is from BMW test drivers for the factory installed Michelin Pilot Super Sport, I think you want get any better source of information. |
baggus0.00 |
06-02-2016, 07:35 AM | #4 |
915
Rep 3,456
Drives: Harrop E90 M3
I seemed to settle on 32-33 front and 35-36 rear when hot.
06-02-2016, 10:40 AM | #5 | |
Rep 8
So just to be clear, I should set the front to 36 psi and rear to 29 warm - correct? |
06-02-2016, 12:50 PM | #6 | ||
7906
Rep 11,785
Otherwise it recommends 32 all around for other tracks |
06-02-2016, 01:31 PM | #7 |
29
Rep 34
06-02-2016, 01:47 PM | #8 |
1823
Rep 2,948
06-02-2016, 03:55 PM | #9 |
7906
Rep 11,785
Calabogie, Mosport, and Trois Rivere are all on my list of tracks I would like to drive in Canada
06-02-2016, 04:27 PM | #10 |
63
Rep 128
You should also add LCMT (Mont tremblant) 1.25 hours north of Montreal, one of the nicest tracks on the east coast. They ran few F1 races there in the early 70's I believe.
06-04-2016, 04:20 AM | #11 |
860
Rep 923
I find it strange that the pressure on the Nurburgring is a lot lower at the rear then at the front. With my Z4M with 19" csl wheels and same supersport tyres I drive with 2.25bar front an 2.35bar rear on the ring... When tyres are hot!
06-04-2016, 04:43 AM | #13 | |
S0THPAW
8717
Rep 7,846
So more stable rear end at Ring... Cheers Robin |
06-04-2016, 06:47 AM | #14 | |
7906
Rep 11,785
Apparently they must anticipate a ton of heat being generated at the rear tires on the Nurbugring and agree with Robin_NL it would provide more grip at the rear. Everything BMW does with this car is respectful of the rear end in an effort to keep it planted, unlike the 1M and M4. Of course they still don't trust journalists or non racers to drive a manual M2 with DCT off on the track.... |
06-04-2016, 06:52 AM | #15 | |
S0THPAW
8717
Rep 7,846
So how can you make the rear end a bit more neutral in that case(NS): less pressure in the rear tyres(= more traction/grip) and more in the fronts(a tad more understeer so to speak) to get a faster laptime. And they're talking about one fast lap(or 2) on the NS. It's not like being on a trackday the whole day... Cheers Robin |
06-04-2016, 06:54 AM | #16 | ||
7906
Rep 11,785
However, a .5 bar/7 psi delta from front to rear is such a MASSIVE difference front to rear ... That's an absolutely *radical* change from even pressures all around... And yes, I would bet those are both settings for one optimal lap in either situation , whether at hockenheim or Nordschleife. Of course to be honest , with the Michelin pilot super sports on a warm day.. That's about all one can achieve ... One hot lap.. Before they just about melt on you ... . Looking forward to a little more time in an M2 and my 1M. On track at COTA in a few weeks ... |
06-04-2016, 07:17 AM | #17 |
1418
Rep 2,560
Drives: Rapidly from A to B
I ran about 35 to 36 hot a couple weeks back and it seemed to work fine. A lower pressure might have been better but there was no greasiness at all at the pressures I ran. Warning though. After cool down I dropped to below 30. For my next session I went out and the tpms sensor turned on the stability and traction control. Also pulled back the throttle significantly. I had to attempt to heat up the tires under these conditions. I then pitted reset the tpms and turned off and restarted the car to get everything cleared. Not very much fun. They need to either disable this nonsense or disable the TPMS whenever you disable DSC and DTC. Of course this is probably against the law for them to do this - disable TPMS. So they should just not have it intervene and simply warn you that your tire pressures are low.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
06-10-2016, 06:24 PM | #18 | |||
3689
Rep 15,081
Drives: '16 M2, '23 GT4
IG: Trackinheels
06-10-2016, 07:22 PM | #19 |
1904
Rep 5,678
You need to chalk your tire's sidewall and adjust higher/lower to manage the contact patch if you want a good hot pressure IMO. Every car/tire combination is different. I'd use some of the recommendations here to start and go from there.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
07-21-2016, 12:55 PM | #20 |
240
Rep 462
In my experience, dropping the pressures for track use is the single most important thing you can do to your car, to ensure safety and car control on the track. Running cold stock pressures will lead to excessively high pressures once hot (I've seen over 50 psi), which will lead to no front end grip (understeer), no rear end grip, overall twitchiness and a very unstable rear end especially under heavy braking/trailbraking. I drop my pressures to about 30 psi cold, which equates to about 38-39 psi hot. In order to get equal hot pressures front and back (if that is your goal), drop the front pressures a bit more because they will heat up more than the rears. Once you set your pressures initially and go out for a lapping session, re-check your pressures immediately afterwards, because 9/10 times they will need re-adjustment.
For reference, I track my car at Calabogie. |
gthal1904.00 |
