E84 (X1) LCI - Halogen to Xenon
05-30-2016, 11:33 PM | #1 |
27
Rep 289
Hi Guys,
Sorry for posting here but there is no dedicated session on E84 board and E90 shares a lot with this model... I retrofitted EU Bixenon (Non AHL ) lights LCI So far done: Added Ground Moved High Beam pin to shutter ... Before coding: Led AE, EYE LID working ... xenon blinking and turns off after a couple seconds, Shutters bixenon working... So I went ahead and coded car adding $522 ... Xenon Turns ON OK!, High Beam ok ... But I lost the Angel Eyes and Led LIP... Maybe I coded something wrong ? Please take a look at FRM TRC Any ideas appreciated ! |
05-31-2016, 01:44 PM | #3 | |
27
Rep 289
I don't want to buy new FRM ... I might supply 12V directly to PIN .. but what wire will have 12V IGN on ... Any ideas ? |
05-31-2016, 02:07 PM | #4 | ||
529
Rep 2,503
Anyway, I'll try find correct pinout for you when I get home later. |
05-31-2016, 08:49 PM | #6 |
27
Rep 289
Progress .. I moved around pins on FRM and rings are ON.. but flickering ...
Xenons not igniting for some reason .. maybe bad bulbs ... Ordered new bulbs ... Any ideas how to get rid flickering my FRM is "AHL" what does that mean ? |
06-01-2016, 12:09 AM | #7 | |
92
Rep 212
To fix rings flickering... try changing the build date in your VO to a year the LCI X1 was manufactured. Find a donor VIN from an LCI car on a dealership website, plug the VIN into a VIN decoder and use it's build date. You can also try adding $5AK to the VO. It refers to "LED Light Elements". Just keep in mind I am not an expert and I'm only sharing information that was shared to me. |
06-02-2016, 08:08 PM | #8 |
27
Rep 289
Hey
I finally completed the retrofit. Everything is working as expected. Didn't need to replace FRM... x1 came with AHL module... so I highly recommend checking before ordering new one I didn't use harness just the stock cables moved at the plug and frm. I didn't install leveling sensor ... but that's a piece of cake. Thank you to everyone here that was helping. I will write up how to ... shouldn't take longer than 2hrs to install everything |
