Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Archoil Diesel Fuel System Cleaner & other Archoil products reviewed
      05-26-2016, 05:38 PM   #1
raptor_f22
raptor_f22's Avatar
United Kingdom
143
Drives: E92 330d M Sport Auto
Thread title updated as discussions/review now include other Archoil products
Background
Decided to give a fuel & turbo system cleaner a go as I thought I could hear my turbo whistling and noticed a gradual decline in performance. Wanted to try and nip the problem in the bud as early as possible. Also thought it was worth testing Archoil's claims about cleaning out the fuel system which could lead to improved mpg figures.
Did a lot of research before purchasing and decided to give Archoil's AR6400D a go as it's a PEA based concentrate - I won't go into details on here but for anyone interested, have a google, sceptic or not, it seems that PEA based cleaners are the ones to go for.
I ended up buying from Power Enhancer http://www.powerenhancer.co.uk/shop-...trate-639.html
Product came with a small bottle of AR6200 fuel modifier and i'd also ordered some AR6300 for on-going treatment.
Application
Easy enough to use, waited until the car had around 10 miles range then added in a full bottle of the AR6400D, filled up 45Litres with Shell's VPower and added 15ml of the AR6200 as recommended.
I also added in 10ml of the AR6300...not sure why, just thought I might as well
Results
I think due to a combination of Vpower and the fuel modifiers there was an immediately noticeable improvement in performance. I regularly use Vpower and regular diesel and can tell the difference straight away with my car. This was like using Vpower on steroids - added to the car being remapped, it really put a smile on my face
As for the main reason for purchasing...after I drained the tank down to 10 miles (covered around 380 miles) I found that:
Thankfully the whistle from the turbo seems to have gone completely. Performance is much more predictable too so seems to have worked well
As for increase in fuel economy... I didn't change my driving style or my usual commuting routes.
Previously I would typically get 28-32mpg. After covering 380 miles the trip computer was showing 36mpg so seems like there was an improvement but perhaps too early to say for certain.
I've now re-filled the car with cheap supermarket fuel and added the recommended dose of AR6300 so will update on here what mpg return I get.
I've already done a 40 mile congested run (e.g. 45 mins to cover 5 miles ) and have some long distance motorway driving coming up this weekend. Typically i'd expect 42-47mpg so will see what it comes out at!
At this stage I'd recommend Archoil's products. Need my gearbox servicing and currently considering their gearbox cleaning fluid too but will need to speak to my indy about that first.
      05-27-2016, 03:58 AM   #2
borinous
borinous's Avatar
38
Drives: E90 320d SE
Interested to see how you get on with this. Ive used V-Power vs supermarket fuel an i have to say i struggle to tell the difference. Maybe my 320d is less fussy?
also didn't realise turbo whistle was a sign of degrading performance. thought they all whistled?
      05-27-2016, 04:05 AM   #3
raptor_f22
raptor_f22's Avatar
United Kingdom
143
Whistle might not have been the best word to describe it - maybe a whining noise? Either way it didn't sound healthy and its usually an indicator that the turbo is on it's way out for a number of different reasons. Could be because of accumulated dirt build up or something else
http://www.aet-turbos.co.uk/blog/sto...rbo-is-failing
http://www.aa1car.com/library/turbo_repair.htm
How many miles has your 320d done?
Will try and keep this post updated if you find it helpful
      05-31-2016, 09:37 AM   #4
borinous
borinous's Avatar
38
Drives: E90 320d SE
hmm not sure ive got either a whistle or a whine.
Its done just over 156k but the turbo has been replaced at around 100k so it should be ok.
thing im more concerned about is the injectors think they could be starting to wear. wondering if any of these treatments help. not sure if the injectors genuinely do wear out or if its just caused by build up?
      05-31-2016, 09:44 AM   #5
raptor_f22
raptor_f22's Avatar
United Kingdom
143
I'm not sure how easy they are to get to but any way of taking them out to look?
I've read in a couple of reports that it's extremely rare for modern injectors to get clogged up as the designs are so much more improved but I guess it can still happen for various reasons
one way of looking at it is that for a relatively small amount of money, it's worth trying out to see if you get any improvements
      05-31-2016, 02:07 PM   #6
djgandy
djgandy's Avatar
146
Drives: E93 M3
2011 M3  [0.00]
If this stuff made it's way into your turbo to fix it then your car has some serious issues! I guess it could clean the exhaust side of the turbine?
Maybe the whistle was from somewhere else? Glad you are happy with the results though.
      06-01-2016, 04:06 AM   #7
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
Tempted to try this
      06-02-2016, 02:21 AM   #8
borinous
borinous's Avatar
38
Drives: E90 320d SE
its fairly invasive surgery to get to the injectors (i've done glow plugs)
But yeah your right it is a small amount of money worth a try i guess
      06-04-2016, 11:41 AM   #9
Kev_G
Kev_G's Avatar
Drives: non
Power enhancer is a great site I often use there products each year on a run to clean the crap out
      06-04-2016, 12:52 PM   #10
raptor_f22
raptor_f22's Avatar
United Kingdom
143
Not sure at this stage, there's definitely been an improvement in the turbos performance though, doesn't feel as sluggish - although I admit that could be for a number of other reasons.
It's so hard with products like these to pin point what results they're responsible for (if any) but I'm still on the positive side for now.
My dad's Mercedes B200 CDI Auto has a horrific rough idle and 97k on the clock (non turbo model). I might give it the same treatment and see if there's any change in that.
      06-04-2016, 12:53 PM   #11
raptor_f22
raptor_f22's Avatar
United Kingdom
143
I agree! Great prices too. Have you used any oil conditioners or the gearbox treatments before?
      06-12-2016, 03:56 PM   #12
dappamikey
dappamikey's Avatar
United Kingdom
Drives: E92 325D M Sport (Evolved)
OK....so I have been running this for a week - done 200 miles and possibly another 30-50 miles before reaching half tank (Tesco diesel). Bear in mind - London city driving......Performance difference is instantaneous, power delivery smoother and acceleration more responsive. I decided to also purchase DPF treatment but will add that on next fill up. So far so good.
Thanks OP
      06-13-2016, 12:56 AM   #13
raptor_f22
raptor_f22's Avatar
United Kingdom
143
Thanks OP
Nice, glad it worked for you! I've now covered around 1500 miles since first using the cleaner and have added the AR6300 at two full tanks of cheap diesel.
The combined mpg i'm getting is now up to 43.4
I'd recommend you get the AR6300 for on-going use dappamikey
      06-14-2016, 01:47 AM   #14
bazz780
bazz780's Avatar
70
Drives: E92 330d m sport
Great reviews
Great thread
Just ordered the ar6400d
For reference i average 25mpg in my 330d m sport which mostly is local london driving with occasional runs on dual carriageways and motorways so will be interesting to conpare
      06-14-2016, 02:02 AM   #15
raptor_f22
raptor_f22's Avatar
United Kingdom
143
Originally Posted by bazz780 View Post
Great reviews
Great thread
glad to help, did you order the fuel additive too? I used them both together
Also, I will be ordering another of the AR6400D as a matter of course given the high mileage of my car
My car is due a service in a month too so i'm also going to order:
AR2300 Fluid System Cleaner
AR2820 Engine Flush
AR9100 Friction Modifier & Oil Additive (still deciding on this one)
Will review those as well and let people know how I get on. Seems like Archoil aren't as widely known as BG and Tuna in the UK. I've only read good reviews about them and my experience is good so far - would be really interested to hear from anyone who's not had a good experience with Archoil please!
      06-14-2016, 08:29 AM   #16
dappamikey
dappamikey's Avatar
United Kingdom
      06-14-2016, 09:45 AM   #17
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
Also ordered 6400d should be coming today
      06-16-2016, 02:13 AM   #18
bazz780
bazz780's Avatar
70
Mine arrived yesterday with what can only be a complementary 20mm of ar6200
Will be tanking the car and trying it out this morning
      06-16-2016, 02:15 AM   #19
bazz780
bazz780's Avatar
70
I dont think its 15ml of ar6200, according to the ratio should be 1ml for 50 litres?
1:5000 ratio for effective treatment
      06-16-2016, 04:11 AM   #20
djgandy
djgandy's Avatar
146
Drives: E93 M3
2011 M3  [0.00]
1:5000 = 1ml for 5,000ml = 5l
so for 50l 10ml, so roughly 15ml for a full tank.
      06-16-2016, 08:12 AM   #21
raptor_f22
raptor_f22's Avatar
United Kingdom
143
These arrived today, picked up all 3 for £35
Took them over to my local indy - TWG Automotive. Will had a quick look, I think he said he's not used Archoil before but the concotion seemed to be solvent free which was definitely a positive. So will be a first for us both.
Poured the recommended amount (roughly) of the AR2300 into the engine block. About 50ml left over, shame they dont give bottles with markings on:
It says on the Archoil website for the AR2300 to be fully effective in fully synthetic oils you need to run it for 4000 miles. I don't think I'll do more than 1500 before my service is booked in but took a snapshot anyway, so will describe what the effects are after the service. Some cleaning is better than none in my opinion.
Will keep you all updated!
      06-17-2016, 05:34 PM   #22
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
How did you guys actually get the stuff into the fuel? I tried today but the metal hole wasn't opening
Tags
ar6300, ar6400d, archoil, fuel system cleaner, pea cleaner
