Bosch Wiper Blade (Aerotwin) A980S vs A073S, whats the difference?
05-20-2016, 12:09 PM | #1 |
46
Rep 232
I'm looking to replace my widescreen wipers, autoglass replaced them in March and now they snatch on the widescreen as if being punched in the face.
Looking at the EuroCarParts website they have two Bosch blades listed A980S and A073S at different prices. Which one is correct for an 06 E90?
05-20-2016, 03:32 PM | #2 |
Photographer
412
Rep 2,643
Is a case of taking your set in and seeing which ones work I imagine. Mine were the more expensive ones, but I went for the Valeo in the end which are the same fitment as the more expensive Bosch ones.
05-21-2016, 02:01 AM | #3 | |
616
Rep 3,194
Drives: E92 325i MSport Coupe
If you look carefully at the ECP illustrations you'll see the fitment is different. My guess is your fitment will be the single pin type (the £37.49 pair).
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
05-24-2016, 02:29 PM | #4 |
Rep 91
if its the same as 335d then you need A073S as the others will go on but you cant use the cover bit (iirc)
i got mine here http://www.ebay.co.uk/itm/221707088129 |
05-24-2016, 03:45 PM | #5 |
46
Rep 232
Thanks for the link
