05-17-2016, 03:47 PM | #1 |
54
Rep 290
Best wheel options for track use
I'm thinking about a second wheels and tires forr track use. Where's a good place to look for a lightweight set of stock size 18 inch wheels? Also, would a square setup be a good ides for track use?
2014 328i Msport - EBII, premium, sport auto.
05-17-2016, 10:05 PM | #2 |
175
Rep 766
Apex
18x8.5 ET38 Arc8's or 18 x 8.5 ET 35 EC-7s and yes run square. 255/40/18 or 245/40/18
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
05-18-2016, 02:02 AM | #3 |
121
Rep 749
Drives: 2016 528i Executive Edition
I went 18x8.5 square for my track setup on my f30.
Guys at apex recommend 235/40/18 as the ideal tire size, with 245/40/18 also a viable option. I chose to go with re-71r as my tire choice. I hoped to get 245 wide but they were sold out across the country so I settled for 235. You absolutely can not go wrong with apex wheels. Absolute best bang for the buck. Super light 18" wheels, awesome price point when you get in on their group buy, and a great company with great customer service. Can you tell I'm a happy customer? Lol |
05-18-2016, 05:46 AM | #4 | ||
1607
Rep 3,943
Square setup: APEX ARC-8 18x8.5 ET38 Michelin Pilot Super Sport 255/40/18 No rubbing. |
06-04-2016, 04:05 PM | #5 |
17
Rep 114
Drives: 2013 BMW 335i xdrive
+1 for Apex setup
18x8.5 et35 EC-7 with 245/40 square FTW |
06-08-2016, 02:26 PM | #7 |
258
Rep 319
I run APEX ARC-8 18x9 ET41 with Dunlop ZII 255x35x18. 5mm spacer up front. I have no rubbing.
I'm in my second season on the ZII and will be needing a new set of tires for next year. I'm not real happy that the Star Spec are more than twice what I paid for the ZII. I can't see that there will be that big of an improvement. I’ve run them at COTA also.
2024 X3 M40i. wife says no Mods since it's aLease.. I see a JB4 tune in the near future.
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune, Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 ,AFE CAI, BMW M Performance Brakes Retired Last edited by Burnt C6; 06-08-2016 at 02:33 PM.. |
06-14-2016, 06:47 PM | #8 | ||
BimmerPost Supporting Vendor
3513
Rep 6,744
F&R: 18x8.5 et35/et38 - 235/40/18 F&R: 18x9 et42 - 245/40/18 This will typically be a direct fit and not require modification to your suspension/fenders (depending on ride height, and tire brand/compound). Feel free to give us a call with any questions you may have regarding track fitment for you F30. I'd be more than happy to assist -Matt
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
left12356.00 |
06-30-2016, 01:02 PM | #9 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Wow, lots of 18x8.5" square setups... I went with 18x9", and there's still some extra room in there (I was even running a 10mm spacer up front at one point, with no rubbing or clearance issues.) While I think 9" is the widest square setup that can be comfortably run on an F30, I am actually planning to get a set of 9.5" wheels, and squeezing them in.
If anyone in the Northern NJ area is interested in a set of 4 like-new black 18x9" Apex ARC-8 wheels, shoot me a PM : )
Ahead of the curve for specF30
07-01-2016, 08:58 AM | #10 |
54
Rep 290
how do you like the dinan suspension?
07-05-2016, 06:46 PM | #11 | |
67
Rep 444
Question on the spacers in the front... Was this for tire clearance, caliper clearance, or just for the hell of it? Based on my rough measurements in the garage I can't clear the strut (this is on an adaptive suspension car so might be slightly different damper body) with an 18x9 et41 and would require something in the et30-35 range to push things outside a bit more. Thx, J |
07-06-2016, 11:04 AM | #12 | |
330
Rep 1,084
rwalker@rwalker.com (I really dislike Private Messaging)
07-07-2016, 09:02 AM | #13 | |
258
Rep 319
I love the way they ride and handle
correct the 5 MM spacer is to clear the Struts. the 18x9 ET 31 PS-7 I run on the Street with 245/40/18's clear no issue.
2014 328i Melbourne Red Sport Line Dinan Dinantronics tune, Dinan Exhaust, Dinan Suspension, H&R Sway bars, 18x9 APEX PS-7 ,AFE CAI, BMW M Performance Brakes Retired |
07-08-2016, 09:44 AM | #14 | |
558
Rep 1,477
Drives: 335i
The Apex ARC-8s in 18x9 are actually ET42 <link>, and with 245/40-18 tires they cleared my OEM adaptive struts up front without any issue (not surprising, as they are one of Apex's recommended fitments). I eventually swapped out my OE wheel carriers for the -0.5deg version, which significantly reduce the clearance between the wheel/tire and strut, and even with those hubs, I ran just a 3mm spacer with no clearance issues. You must be at the outer limit of fender clearance... I ran a 10mm spacer with my ET42 ARC-8s for a while, and had no rubbing issues, but it was soooo close to the fender.
07-08-2016, 01:41 PM | #15 | |
67
Rep 444
I also went back and rechecked my notes... I was fitment testing with a fairly chunky 255/40 tire which drove my concern for strut clearance. |
07-08-2016, 01:43 PM | #16 |
67
Rep 444
07-08-2016, 04:13 PM | #17 |
558
Rep 1,477
Drives: 335i
Correct - I have the M Sport brakes (same as M Perf, minus the dimples in the calipers) and no clearance issues.
07-14-2016, 12:54 AM | #18 |
7
Rep 34
Also running 18x9" ET42 APEX ARC-8 Wheel square on Dunlop ZII 245/40R/18 with Burger Tuning 10mm spacers front and 15mm spacers rear. |
09-12-2016, 06:56 PM | #20 | |
309
Rep 1,733
Drives: 2003 M3
EDIT: Just saw your photo shoot pics. So my only question is did you look into a 255 front or it won't work? Last edited by SLOWER; 09-12-2016 at 07:04 PM.. |
09-13-2016, 10:55 PM | #21 |
175
Rep 766
Should have no issues with a 255, its just that the track tire choices in 255/40/18 are very limited - basically the PSS or the RE71 most of the other options are suboptimal and the PSS gets pretty greasy once hot.
Drop down to 245/40/18 and you get Rival S, RE11, RE71, Direzzas, RS3v2s etc Im running 255 square PSS on the street and change over to 245 square RS3s at the track.
09-14-2016, 04:43 PM | #22 |
309
Rep 1,733
Drives: 2003 M3
