05-14-2016, 10:05 AM | #1 |
354
Rep 941
Jb4 Bluetooth connect
I installed the Bluetooth connect a few days ago and was curious to see how accurate those that have it think it is?( display) It's a 2013 335i pwg with a downpipe and intake. I'm running map 5 with 93 octane and have seen boost as high as 21 psi on max boost display. Also afr is all over the map, usually 14.5-14.7 but have seen 21 and lows in the 3.8 range.
I haven't had a chance to log yet and have been running the jb4 for almost a year with zero issues. Firmware is up to date and I'm running OBDii |
05-14-2016, 10:16 AM | #2 | |
2077
Rep 2,641
05-15-2016, 02:47 PM | #6 | |
498
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
05-15-2016, 06:12 PM | #7 |
354
Rep 941
05-15-2016, 06:30 PM | #8 |
498
Rep 902
Yeah that's all that matters. As for exceeding the boost safety and seeing boost peak over safety that's just what happens when you let off the throttle or shift, the throttle plate snaps closed while the wastegate is still closed. Boost pressure is calculated at the TMAP sensor on the charge pipe and when the throttle snaps closed, pressure builds higher and peaks higher on the gauge before the airflow reverses back to the turbo and opens the diverter valve releasing pressure back into the turbo inlet.
