Feeler: LCI E90 M-tech bumper w/ Volkommen Design PPU lip
05-04-2016, 12:02 PM | #1 |
I got lei'd
844
Rep 7,593
You've probably seen my ugly car before and I've decided to try another front bumper. Or keep this one and do a little metal wide body modification but I'd like to see if there are offers. JGmods E90 LCI M-tech front bumper with gloss black grills with Avery titanium silver wrap. (why did I do that? I wanted my color and clear bra at the same time) So whoever get's this doesn't have to repaint it, you have to paint it. It is still primed underneath the wrap. This front plate cover is missing, so I have an OEM cover but it won't fit to the bumper because of the inner tabs. Best thing to do with it is to have the shop bondo it and have it permanently stuck from the inside or do a plate delete and bondo the front of it and make it all look flat, very nice. w/ Volkommen Design PU front lip. There is no other way to keep the lip on to the bumper unless you drilled into it. I tried mimicking the drill sites like @joshavery0615 on IG and it has held up despite my freeway runs, heavy rain, it is also wrapped in Avery vinyl. will come with a carbon fiber lip that I bought from Mode Carbon that is intentionally used for the V2 lower front lip. Once I get the new bumper I will have a box to ship it in. Or even better, if you're local (NorCal), I can install the whole front for you and if the front lip is sticking to far out for your liking, I will drill up more spots on the CF lip so you can either extend it in or out whenever you want. It will come with the fog lights and grills, I have 3, I used to have 4 until my wife ran it over. FYI, I have already made the lower grills gloss black with clear on top. Last edited by Route 16; 05-05-2016 at 02:55 AM.. |
05-06-2016, 02:23 AM | #6 |
I got lei'd
844
Rep 7,593
They are LCI halogens and since I didn't have projectors, I took the risk of just adding Orion v4's and they worked perfectly. All the original rings are still intact with no power to them and painted gloss black, the orion v4 rings are glued to them instead of having them glued to the chrome housing, so it looks like the rings are "floating". I'll PM you his number, on the forum his name is "uber" his name is Dominic he can pretty much do what OSS does.
