DCT service
04-26-2016, 03:52 PM | #1 |
Rep 14
DCT service
My n55 With DCT has done 46.5k miles now, when should I service this 'lifetime' gearbox oil? And where? I'm in Southampton, brystone are quoting me £400 which is a bit steep? Any advice
04-27-2016, 09:37 AM | #2 | |
283
Rep 2,343
You are supposed to never need to change it. I changed mine (at just under 50k miles) as it was leaking. A common issue. http://www.e90post.com/forums/showthread.php?t=1147434 £400 is a fair price. Just make sure you have confidence in them. You don't want them to mess up a trans that was $10,000 new. They have to make sure they fill it up with the right level and that it's not short on fluid.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos) 11.74@129mph (GC Turbos) |
04-27-2016, 02:29 PM | #3 |
96
Rep 2,204
I have DCT and my car just turned 70k. I changed my oil at 50k and also the sump cover - this stops the oil leaks at least temporarily. They all leak btw.
I think £400 is well steep. I use TWG automotive in Camberley which is a bit of a drive for you but top guys.
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads. Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips |
