Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > After market turbos
      04-26-2016, 08:58 AM   #1
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
After market turbos
What would be the install cost for aftermarket turbo chargers?
E92 335i
Maybe 5 hours labor?
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      04-26-2016, 10:15 AM   #2
abeardo83
abeardo83's Avatar
United Kingdom
96
Drives: E92 M3
2008 BMW M3  [0.00]
Including taking off the old ones? Id say more than 5 hours. It's nearly an engine out job.
When mine were replaced and started rattling again, the owner of the garage that did the original job nearly started crying at the prospect, haha!
      04-26-2016, 10:25 AM   #3
windymissile
67
Drives: 335i M Sport
It's booked at 12 hours.
WM
      04-26-2016, 02:31 PM   #4
abeardo83
abeardo83's Avatar
United Kingdom
96
Drives: E92 M3
2008 BMW M3  [0.00]
WM
12hours. Bleurgh.
I'm told it's an absolute Cnut of a job. Fair play to BMW for designing them so well, but Jesus, they didn't think about ever replacing them!!
      04-26-2016, 05:00 PM   #5
RajB
RajB's Avatar
448
Drives: E92 335i
I've spoken to a few companies about this and all have come back with 11-12 hours. BMW did mine last year under warranty but again took them about that sort of book time.
E92 335i / M3 Hybrid - The Build
      04-27-2016, 06:48 AM   #6
E92 420
United Kingdom
48
Drives: 2006 Auto e92 335i
As people say budget for 12 hours but it all depends on the garage. I had friend do mine once and he had the job done within 8 hours. I Dropped the car off before work and collected after.
UK
V8bait Tuned
Built motor FBO 335i
      04-27-2016, 07:15 AM   #7
Dann
Dann's Avatar
133
Drives: E90 LCi 335i
Originally Posted by abeardo83 View Post
12hours. Bleurgh.
Fair play for designing them well?
You're talking about the N54 twins
Designed well?
Erm....wastegate rattle failures at 10/20k
I don't call that well designed.
      04-27-2016, 08:26 AM   #8
abeardo83
abeardo83's Avatar
United Kingdom
96
Drives: E92 M3
2008 BMW M3  [0.00]
I meant the integration directly in to the manifolds. The turbos themselves are great. The wastegates, not so much!
      04-27-2016, 09:28 AM   #9
AWSAWS
AWSAWS's Avatar
283
12 hours, wow!
Mine are still going strong at 54k miles. I'm just interested in a stage 2+ upgrade. Running mine at about the max they will take right now. 21 to 22 psi under power, spiking to 25 psi on the shifts.
Would need a high pressure fueling solution and upgraded clutch to go the full
~750 whp.
POWER!!!!!!!!
      04-27-2016, 10:31 AM   #10
gangzoom
1685
Drives: E90 335i M sport
Originally Posted by AWSAWS View Post
12 hours, wow!
~750 whp.
POWER!!!!!!!!
750 whp, that would be nearly 900bhp at the crank.....As long as your happy with the dyno read out
      04-27-2016, 10:55 AM   #11
old grey steve
old grey steve's Avatar
United Kingdom
283
Drives: MK 7.5 Golf R
Officially on paper its around 10 hours but trust me its longer than that 12 hours is sensible re timing mine took to come out and be replaced around 14.5 hours think about it even removing replacing the downpipes can chew as many have discovered on here a good 4 hours plus
      04-27-2016, 11:09 AM   #12
windymissile
67
What would you charge for this Steve?
WM
      04-27-2016, 02:33 PM   #13
lolololol
United Kingdom
96
Drives: M4 F83
12 hours, wow!
~750 whp.
POWER!!!!!!!!
Hmm no sir - you will not achieve this power. You will need a different car
Engine Mods: VF HEX Stage 2, ER Charge Pipes, VRSF Catless Downpipes, BMS Intakes and PCW Exhaust Mod
Running Gear Mods: HRE Flow Form F01, Yellow Stuff pads.
Cosmetic: Performance Grill, Lip Spoiler, Splitters, Side Skirt Extensions, Diffuser and BMS Tips
      04-28-2016, 02:21 AM   #14
abeardo83
abeardo83's Avatar
United Kingdom
96
Drives: E92 M3
2008 BMW M3  [0.00]
Glad you said that - I was thinking the same!!! 900BHP at the crank?!
      04-28-2016, 06:42 AM   #15
E92 420
United Kingdom
48
700whp is possible on straight e85
UK
V8bait Tuned
      04-30-2016, 02:48 AM   #16
Cerbera9
9
Drives: E92 335i 2007
Swapping the turbos is a PITA job! having done it a few times now, firstly in situ and then the 2nd & 3rd times with the engine removed its def much easier to remove the engine to swap the turbos esp if your combining it with other work, like replacing the clutch while the engine is out.
      04-30-2016, 04:14 AM   #17
windymissile
67
What do you charge for this, Steve?
Wm
      05-01-2016, 09:40 PM   #18
AWSAWS
AWSAWS's Avatar
283
Nope
Dyno at 736whp already. Calcs show enough flow for 750whp
http://performance.vargasturbo.com/bmw-products/n54/
      05-02-2016, 10:30 AM   #19
mob17
mob17's Avatar
United Kingdom
400
Drives: E92 335D
Bloody hell 750whp would be epic!
What is your gearbox rated at? Could it handle 675ft.lbs?
      05-02-2016, 01:55 PM   #20
old grey steve
United Kingdom
283
Wm
On paper you're looking at just over £700+VAT, the big things with these cars and we've done 3 including my car is the fact that I've seen a variation re times taken, sounds crazy but that's what I've seen, therefore even a 'realistic 12 hours' could increase re times hence the quoted 14.5 hours I stated above and therefore I'd always, always stress this before taking any car on thst times may increase, I've seen enough of these cars now to know they chew time and throw up issues to know that there will at times be a sting in the tail waiting to catch you when you least expect it and thst sting is time that will = money money.
Theory says though complicated by a lack of space the turbos should be able to be extracted with the engine in situ, but it's just not that easy as said putting catless pipes on can take 4 hours with ease which in theory is a good third of that 12 hours stated hence the warning above, however once you've extracted the engine everything is just far more accessible it makes you think about going down this route not only for the turbos but to address other know or troublesome 335i issues such as the annoying rear inlet pipe thats near impossible to cleanly extract with the engine in place plus it helps you identify annoying issues such as oil leak issues again something 335i's suffer from plus you can clean residue oil away a hell of a lot easier.
If I had my time again I'd actually look really closely at engine extraction as you can address a lot more in the one visit but one things for sure its a real PITA whichever direction you run with.
      05-03-2016, 05:45 AM   #21
AWSAWS
AWSAWS's Avatar
283
Yes I think there in lies a problem. 600ftlbs seems about the max and would need the Dodson clutch upgrade. I'm going to look to see what the tuned M5 guys are doing with their DCT boxes. I know the stock clutch is the same but the actual transmission might be a bit different.
Manuals seem able to be upgraded to take the power and the Autos are capable of alot. DCT is a bit of a mystery. There must be a reason no future M5 and M6's will be manuals anymore though. Same with the 335D.
      05-03-2016, 05:46 AM   #22
windymissile
67
Thanks Steve. Good to know.
WM
