Carly or schawben Scan tool?
04-22-2016, 01:11 PM | #1 |
11
Rep 64
Wanted to get the 335D member's opinions on these two units. Any thoughts on which one to go with?
Carly BT dongle, plus app = $117 schawben Scan tool = $199 Thoughts, especially from those that have perhaps used both? |
04-22-2016, 03:45 PM | #2 |
54
Rep 215
Drives: E39 M5, F15 35d
Sub'd, curious also
04-23-2016, 09:33 AM | #3 |
307
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
I own Carly, but find it extremely buggy and it's more expensive than you think if you want all the features. Personally I think I'm going to buy the schwaben tool as I own a BMW duh and a mini, and it seems to work well for both.
04-24-2016, 06:55 AM | #4 |
37
Rep 115
Drives: 2010 BMW 335D
Carly is quite buggy, and can be dangerous. A number of people have bricked FRM modules during coding operations.
It is FAR more expensive that other solutions.
2010 BMW 335D: INPA & K+DCAN Cable, BMWhat BT Adapter, JBD, M3 Suspension Components, ECS Tuning Trailing Arms, 193M Gloss Black Staggered w/Michelin Pilot Super Sport, LUX V5 Color-changing LED Angel Eyes, KUDA Mount, SolarGard 23/17 Charcoal Tint, Plasti-Dipped Grill - Many more mods coming!
04-24-2016, 07:04 AM | #5 |
Kind of a Big Deal
167
Rep 857
RDA that is pretty serious -- can you point to a board member who has bricked their FRM? I have Carly and while I pout up with the bugs I won't put up with it potentially trashing my car. Thanks.
04-24-2016, 07:30 AM | #6 |
37
Rep 115
I have my bricked FRM on my workbench, and if you google it, you'll see others. My colleague also had the same problem and both of us have the official BMWhat / Carly OBD dongle and legitimately purchased app, and non-rooted devices.
In my instance, I have TWO android devices. I used one to perform the initial coding (enable simultaneous fogs + high beams, and remote mirrors). Months later, I attempted to make a further adjustment with my second device, only to brick the FRM. My colleague replicated the issue (to his dismay) and we were both stuck with non operational windows/lights, etc. Carly seems to be OK for non-coding items, but for coding it does seem to be hit or miss. I'll stick with my hardwired INPA setup for coding as that is reliable (so far). Google "bmw carly FRM". I still have my bricked FRM which I'll look into repairing on the bench when I can free up some time.
04-24-2016, 06:52 PM | #10 |
296
Rep 233
From what I can tell, Schwaben is a brand name that ECS Tuning made up to make their (usually) Chinese tools sound like they are of German origin. This scanner appears to be a rebranded Foxwell NT510 available for much less than what is sold through ECS. I saw it on Amazon for $170
04-24-2016, 06:55 PM | #11 | |
57
Rep 210
04-24-2016, 09:52 PM | #12 |
14
Rep 71
Drives: (sold)335iS, 440ix Gran Coupe
04-25-2016, 12:06 AM | #14 |
213
Rep 2,210
Depends on what you're planning to do. Coding and serious diagnostics should always be done over a wire in my opinion. If you want something you can just leave plugged in and read codes or just log if you feel like it, it would seem Carly is the way to go.
04-25-2016, 12:53 PM | #15 | ||
Ballin' out of control.
520
Rep 1,289
BMWhat Carly Killed Lighting System In my opinion, the best tool to use is BMW Standard Tools 2.12; INPA for diagnostics, NCS-Expert for coding, etc. Again INPA for 335d You just need a good cable. I highly recommend the K+DCAN cable from one-stop-electronics.com. It's plug and play as described in my BMW Standard Tools 2.12 DIY. Just plug it in and Windows Update will install the latest drivers for you: http://www.one-stop-electronics.com/...&product_id=16 If you want something less expensive, the cable from bimmer software will work. However, it's not plug and play. You will have to download the drivers from FTDI and manually install them, which can be a PITA: http://bmwsw.com/cables
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms
04-26-2016, 09:36 AM | #16 | ||
New Lifetime Replacement Policy
815
Rep 11,738
Both are great tools, depends upon what you're looking for. Personally for coding, I use INPA/NCS. For quick reference I have the dongle in my car and my phone is always in my pocket, for more detailed scanning I like the Schwaben scan tool over app based tools.
Prime Pump - yes Force Regen - I don't have a deisel on hand to confirm but per Foxwel yes it does. Register Battery - registartion yes, battery type chages not with the current software update. Battry type changing is a feature we've requested to be added to the tool, Foxwell is currently looking into adding this code line option. Quote:
Our scan tool is based on the Foxwell NT510 correct, you can get the unit cheaper, but watch out for software packages. Per Foxwell there are no other versions of this tool sold which carry all our packages out of the box. Good bit of info in the link BudgetBimmer posted as too what the tool can do, what's being unlocked as we speak, what's included vs the other tools, etc. -James Last edited by ECSTuning; 04-26-2016 at 09:46 AM.. |
04-26-2016, 09:25 PM | #17 | |
57
Rep 210
04-27-2016, 09:25 AM | #18 | |
815
Rep 11,738
-James |
04-27-2016, 11:09 AM | #19 |
54
Rep 215
I'm eagerly awaiting the added coding ability, I'll be first in line to buy one once that's available.
04-27-2016, 06:02 PM | #20 | |
57
Rep 210
