Headlight broke - option to upgrade?
04-20-2016, 03:17 PM | #1 |
23
Rep 197
My passenger side headlight points straight at the ground. My mechanic indicated that it needed to be replaced. Since replacements aren't cheap, is there an upgrade I should consider, or is the upgrade simply the bulb?
Edit: I have the adaptive xenon's on my LCI |
04-21-2016, 04:37 PM | #5 |
494
Rep 1,416
Questions: Did you hit a pot hole recently AND do you have run flats?
I keep seeing threads like this and I think there is a correlation between the harshness of run flats and the shock it sends thru the front end when going over rough roads. Headlamps on a $50,000 car shouldn't just fail like that after such a short time. |
04-22-2016, 08:42 AM | #6 |
23
Rep 197
I agree. I don't have runflats, but I hit a serious pothole last year which damaged my wheels and tires, that I'm guessing is when it may have broke and I just didn't notice it until recently since I don't drive in the dark very often.
04-22-2016, 11:40 AM | #7 | |
douchebaggo
186
Rep 972
http://www.e90post.com/forums/showthread.php?t=494479 |
