proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > Classifieds > Sponsors Classifieds > Suspension / Brakes / Chassis / Spacers
      04-20-2016, 01:13 PM   #1
kevin @ eas
BimmerPost Supporting Vendor
kevin @ eas's Avatar
Drives: 2015 BMW M4
▀▄ eas | Moton Adjustable Coilovers for M3/M4 - 2/3/4 Way - [Master Dealer]
Now available from EAS is the full line of Moton coil overs for your BMW.
PM today for inventory, questions and pricing.
Moton 2-Way Sport Coilover System
The Sport line is designed for the serious club racer and high performance street driver. This ultimate suspension system is by far the finest quality and best handling suspension system on the market today.
Featuring remote reservoirs for superior fluid temperature control, quick release hydraulic lines (on most models) for easy installation, separate compression and rebound damper valving adjustment and height adjustable spring perches, this kit is beyond the more common coil-over systems on the market. If your driving can benefit for the ultimate in suspension tuning, then this kit is for you.
Specifications
The Moton Sport damper features 15 positions of bump adjustment on the remote reservoir and 15 positions of rebound on top of the piston rod. Each adjustment done to the damper is very noticeable to the driver. Our Sport dampers are designed to be uncomplicated, easy to use and to deliver the absolute best performance. The Sport dampers perform really well at low speed as well as high speed velocities which gives you total control regardless of the conditions. The reservoir is connected by a high pressure hose and is equipped with swivel banjos for easy installation of the canisters in the car regardless of the position. The damper bodies are produced from the highest quality steel or aluminum. The shaft are induction hardened and chrome plated. The canister pressure can be varied between 6 - 18 bar (100 - 300 psi) to help support the car in high speed cornering with soft springs.
Benefits include
- Comfortable on daily roads
- Easy to adjust to a real race setup
- Easy to work with
- Every single adjustment done is very noticeable to the driver
- Proven reliability
- Wide range of spring rates can be used
- Improved platform stability
- Improved traction, higher grip level
- Improved curb stone and bumpy track control
- Improved tire wear
Features
- Separate Bump (15) and rebound (15) control
- Ride height adjustable
- Unique blow off valve system in remote reservoirs
- Large piston rod diameter for more fluid displacement
- Adjustable gas pressure for added lifting force
- Large main piston for quick response
- No preloaded valve stacks needed for low speed damping control
- Swivel banjo hoses for easy installation of remote reservoirs
Moton 3-Way Motorsport Pro Coilover System
The 3-Way adjustable Moton damper features 15 positions of high speed bump, 6 positions low speed bump and 15 positions of rebound adjustment. The low speed bump adjuster is located on top of the high speed bump adjuster and can be adjusted in dependably. The low speed bump adjuster is very effective in helping to control body roll while adding to turn in and is effective in controlling pitch and squat. The 3-Way adjustable Moton damper is using, like the double adjustable damper, a unique blow off valve system in the canister to totally control curb stones and bumpy track conditions.
Benefits include
- Improved tire wear over race distance
- Easy to adjust and work with
Features
- Unique blow off valve system in canister for high speed bump control
- Separate Bump and Rebound control
Moton 4-Way Motorsport Pro Coilover System
The 4-Way adjustable Motorsport damper has been developed over the last few years in conjunction with many professional racing teams all over the W orld. After winning the FIA European Touring Car Championship (ETCC) in 2004 with our Triple adjustable damper, we designed and developed this unique 4-Way damper with Andy Priaulx’s Team in preparation of the 2005 FIA World Touring Car Championship (WTCC). The rest is history and the 2005, 2006 and 2007 FIA WTCC title was clinched by Andy Priaulx running the Moton 4-Way damper system.
Specifications
The 4-Way adjustable Motorsport damper is available as a McPherson Strut in either Aluminum or Steel or as a Aluminum Coil-over damper. It can be custom built to your specifications. The Moton 4-Way damper features separate low- and high speed bump and rebound control. The 2 rebound adjusters are located on top of the piston rod and adjust completely independent from each other. Both low- and high speed rebound do have a adjustment range of 20 clicks each. The 2 bump adjusters are located on top of the reservoir, the low speed bump can be adjusted into 6 different settings by turning the small knob on top of the reservoir. The high speed bump can be adjusted into 15 different settings by turning the large knob on top of the reservoir. The 4-Way damper is featuring a unique double piston design. The primary large main piston does have a double non preloaded valve stack on it for bump and rebound control and is designed for quick response during the smallest movement of the piston. The secondary piston is designed with the use of a unique blow off valve system for high speed rebound control. The low speed rebound is controlled by adjusting an internal needle valve.
Benefits include
Features
- Double piston design
- Unique blow off valve system in both bump and rebound
- Separate Low- (6) and High (15) speed bump control
- Separate Low- (20) and High (20) speed rebound control
Models Supported
2015+ F8X M3/M4
Ordering:
Phone:
You can reach us directly by calling 866.669.0705 x31 to place your order over the phone.
Payment:
Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone)
Other Payments:
Money Order/Cashier's Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods.
Shipping:
All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees.
Hours of Operations:
Monday - Friday from 9AM to 5PM PST
Saturday - 9AM-2PM PST
Sunday - Closed
Retail Location/ Installation Center:
Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell!
Contact Info:
Phone: 866.669.0705 x 31
Email: Kevin@europeanautosource.com
Website: http://www.europeanautosource.com
Feel free to contact us via PM, email, or phone if you have any questions - or to schedule your install today!
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      11-29-2016, 06:12 PM   #2
kevin @ eas
Drives: 2015 BMW M4
Thanks for the inquires
EAS your # 1 source for Moton coil overs
PM for details and pricing
      12-27-2016, 06:09 PM   #3
kevin @ eas
Drives: 2015 BMW M4
EAS your #1 source for Moton coil overs
PM today for details and pricing
      02-16-2017, 05:52 PM   #4
kevin @ eas
Drives: 2015 BMW M4
For the Ultimate track experience
      05-04-2017, 05:02 PM   #5
kevin @ eas
Drives: 2015 BMW M4
Motons your #1 choice for suspension
      05-06-2017, 03:02 PM   #6
ninekrpm
ninekrpm's Avatar
536
Drives: F80M3 (Track) / E92M3 (Street)
Please send me quote for a setup for an F80
-2way dampers with quick disconnect canister setup on all four corners
-2.25 spring HW (no springs needed)
-Rear shock mount
      05-06-2017, 03:59 PM   #7
kevin @ eas
Drives: 2015 BMW M4
-Rear shock mount
PM Coming your way
      07-18-2018, 12:17 PM   #8
kevin @ eas
Drives: 2015 BMW M4
Enjoy Moton/AST Summer sale
10% off
      08-07-2018, 06:10 PM   #9
kevin @ eas
Drives: 2015 BMW M4
Moton Summer sale still going
PM today to get best pricing this year
      03-21-2019, 04:34 PM   #10
kevin @ eas
Drives: 2015 BMW M4
      03-29-2019, 07:10 AM   #11
FlyingLow78
The G8X is a disaster. 🤮
930
Drives: Not a BMW anymore
PM’d
      03-29-2019, 01:26 PM   #12
kevin @ eas
Drives: 2015 BMW M4
Originally Posted by FlyingLow78 View Post
PM’d
PM sent
      09-05-2019, 06:22 PM   #13
kevin @ eas
Drives: 2015 BMW M4
PM today to get yours
Search this Thread:
Advanced Search
f80post
