M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Measuring M2 wheel fitment today
      04-20-2016, 12:43 PM   #1
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Hey guys, sorry for the tease. I'm going In at three to have this thing measured. What are some specs you guys would like to know.
I may even have a few test fitment pics you guys and gals before the day is over.
Appreciate 3
      04-20-2016, 02:08 PM   #2
Twix
Twix's Avatar
657
Drives: 2011 e91
Exact clearance to the inner, outer and full lock front and rear of the front wheels. Take a measurement of the actual fender lip too. And then do the same for the rear minus the turn radius bit
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      04-20-2016, 03:35 PM   #3
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
The measuring is done. The went through everything. Back to back with a gt4, what a looker. They are sending me an email with the exact specs. I don't have offsets yet and a large list of other things.
Some rough estimates so far
Conservative/big tire safe - 9.5"fr 10.5"rear
Aggressive-ish - 10"fr 11" rear
      04-20-2016, 03:53 PM   #4
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Would love to get strut to tire/wheel clearance. Plus inner fender to tire/wheel. I've use a string with a nut on the end held on the inner fender edge as a reference. Same measurements needed in the back.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      04-30-2016, 03:53 PM   #5
M3 Adjuster
Albania
7906
Drives: 1M, X1 M Sport, E46 325ic
I highly recommend 10" square if possible.
You give up a little bit of tire width in the rear but your tires will be happier and your wallet will thank you
      05-01-2016, 10:50 AM   #6
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
265/35 front and 275/35 rear would be my ideal. Call me crazy if you want. So will it fit?
      05-01-2016, 02:07 PM   #7
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
That will fit no problem. 275/35 up front and rear will probably be the track choice
      05-18-2016, 07:26 PM   #8
Fullofdays
41
Drives: m
curious -- will a square setup change the balance? heard that a few of the performance driving school instructors recommended staggered
      05-18-2016, 08:36 PM   #9
Hossel19
63
Drives: M2
+1
Will a square set up prompt MDM to intervene more frequently during spirited driving or on the track?
      05-18-2016, 09:25 PM   #10
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
It will just dial out any understeer. Probably turn in understeer if anything with this chassis right?
The slight staggered setup is safer for BMW, the front axle will warn you before someone visits a ditch.
      05-19-2016, 06:14 PM   #11
clubsport
204
Drives: LBB
Originally Posted by ashburyn54 View Post
Hey guys, sorry for the tease. I'm going In at three to have this thing measured. What are some specs you guys would like to know?
Forgeline Motorsport is carrying this out. I may even have a few test fitment pics you guys and gals before the day is over
Are you only looking into 19"? I would love to have numbers so I can work out a square 18x10 set.
      05-19-2016, 06:16 PM   #12
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
I'm only looking into 19's. Although the specs shouldn't change for 18's necessary. Small differences
      05-19-2016, 11:30 PM   #13
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
275/35 or 275/30? 35 seems pretty tall doesn't it? For 19" wheels?
Current
AW BMW M2
Past
VO BMW 1M
      05-19-2016, 11:48 PM   #14
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
A 30 wouldn't be a bad choice especially on a wheel around a 9.5 or ten. A 30 sidewall is pretty small though. 275/30 would match nicely with the stock 245/35 diameter, still a bit shorter but close enough. I guess I had always planned on running the stock 265/35 up front with a 275 in the rear.
I'm not a fan of super small sidewalls anymore. As this will spend 99% of its life on the road. I don't think a 35 sidewall with a 265 is too much tire, for some reason 275/35 sounds worse to me. I think without proper camber adjustment and stiffer spring rates we would run into rubbing problems if dropped.
As always this is just speculation until I throw something on here.
      05-20-2016, 08:36 PM   #15
Fullofdays
41
Drives: m
I'm looking at the same setup for track duty. Forgeline's website shows their monobloc for m3/m4 as 18 x 10
      05-22-2016, 10:05 PM   #16
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
Yep. That's the stock basic setup for great tire options. Pretty much setup to run a Pirelli World Challenge slick if your heart desires. I know turner did
      05-23-2016, 12:50 PM   #17
Fullofdays
41
Drives: m
So what's the straight dope on offset and tyre fitment? I'm hearing that the M2 is a totally different animal from f30 M3's.
I'm wanting to run A7-R7's and getting wheel fitment before June jam at Road A is proving difficult.
      05-23-2016, 12:57 PM   #18
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
So what's the straight dope on offset? I'm hearing that the M2 is a totally different animal from f30 M3's.
Trying to get wheels and tires before June jam at Road A is proving difficult.
I have yet to order anything. From what I've seen a 9.5 at et28-32ish or 10 et33-37ish up front is spot on. Rears are looking like 10 et25 or 11 et37ish out back.
Higher numbers for larger tires and less camber. Lower is more aggressive.
      05-25-2016, 01:16 PM   #19
Franklin Joseph
57
Drives: BMW
So 18x10 et25 square with a 10-12mm spacer up front should do the trick?
      05-27-2016, 12:00 PM   #20
OrangeCrush
1236
So you can run a 10" et 37 wheel up front without hitting the suspension? I wonder if the stock rears will fit up front.
Current
AW BMW M2
Past
VO BMW 1M
      05-27-2016, 07:16 PM   #21
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
This is my only concern. I need to throw the tears on there and see what the clearance is. I was doing the math for fender clearance.
      05-27-2016, 07:18 PM   #22
ashburyn54
ashburyn54's Avatar
625
Drives: f87 M2
No. That won't fit in the front. Higher offset means less aggressive. If you ran a 15mm spacer on a 18x10et25 that would be far too aggressive. It would be 18x10 et10. Unless you have about 10 degrees of negative camber and a 225/35 it wouldn't fit haha
m2
