04-20-2016, 12:25 AM | #1 |
698
Rep 1,514
Anyone fitted a Dashcam yet?
It may be a bit soon but has anyone fitted or have plans on fitting a dascam anytime soon?
Am planning on installing a Blackvue DR650GW -2ch when my car arrives. I believe the fuse box on the 2 series is in the boot so was wondering what peoples recommendations are for running the wires from the front to back? Had a quick look on the 2 series forum and running them along the top of the window trim appears popular but i'm weary of the airbags, i'm a bit concerned about just tucking the wire behind the top of the A-pillar trim as they may foul the airbags if deployed so does anyone know how to remove the trim safely, i'm a bit concerned with the Airbag being behind there.. |
04-20-2016, 02:03 AM | #2 | |
4398
Rep 2,856
Drives: BMW M2 CSL Turbomeister
MR |
04-20-2016, 02:11 AM | #3 |
698
Rep 1,514
04-20-2016, 03:11 PM | #4 |
Da Baus
283
Rep 259
I got the same blackvue unit, will do the install after I get the car back from xpel/tints. I also got the MotoPark multi-safer so it keeps running for a couple hours after the car is turned off. Check out this DIY for the f30, our install should be near identical
http://f30.bimmerpost.com/forums/sho....php?t=1183385 also, there is no harm in tucking the wires just past visibility. you don't even need to take the a or c pillars off to do the install. If you did, i'd at least unplug the battery.
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
05-15-2016, 09:41 PM | #5 | |
698
Rep 1,514
Have you had chance to install the Blackvue, if so how did you go? |
05-16-2016, 12:46 PM | #6 | ||
Da Baus
283
Rep 259
