HELP - E93 rear window won't roll down!
04-17-2016, 03:50 PM | #1 |
Rep 26
So long story short I went to put down the convertible top of my 2009 e93 today and the rear passenger window won't roll down. I noticed that I can push it and it's somewhat loose. I can hear the switch clicking in the glove box and I believe I heard the motor as well. My best guess would be off track or bad regulator. I removed the rear panel in the car to access the winow but unlike the doors there doesn't appear to be a way to access it. How do I get to the window? Any ideas what could be causing the window to stay up and not go down? Also this warning is displayed:Note: This is a repost of the symbol, mine does not have that code just the window and exclamation point.
All other windows work fine and the window master control switch was relaced last year so I don't believe that is the problem. Any advise would be greatly appreciated, thanks! |
04-17-2016, 04:18 PM | #2 |
BMWCCA 149159
38
Rep 847
E93's had a serious issue with burning out motors mostly the rear ones and there was a service bulletin that helped to solve this problem. It entailed stopping power to those motors. I am guessing that your motor is toast. Best suggestion is to check the connectors with a VOM to see if power is reaching that connector to the motor..
04-17-2016, 04:34 PM | #4 |
Head Fry Cook at McBurgertown
507
Rep 1,005
If you heard the motor, it's probably the window regulator.
I've replaced three on the two E90's I have. I could hear the motor every time; it's an easy DIY. |
04-17-2016, 04:48 PM | #5 |
Rep 26
It is an e93 and I can't figure out how to access the rear window, I removed the panel but there is no access to the window.
