Advice needed on E92 335i
04-15-2016, 04:57 AM | #1 |
Eric_Y
103
Rep 456
Drives: 2016 340i, 2010 E92 M3
Hi all,
I am thinking to upgrade my 325i to 335i for more power and fun. Reliability is quite important to me, have done some research about 335i`s reliability. Known that N54 causes more issues than N55, so I would like to pick up one with N55. To me tune potential is not as important as reliability, so should be a N55 motor with no more than 50000km for sure. Just have some uncertainties about N55, any advice is greatly appreciated 1. Has BMW really worked out a solution on HPFP issue on N55? Is the new pump (943) approved to work with problem free? 2. What about the lifespan of the turbo in real life? 80000Km? Never owned a turbo BMW so no idea at all. 3. Some complains DCT easily got issue, I am not clear with this and didn't find too many information. Any one would like to add his/her opinion? 4. I noticed 335i exhasut pipe is much more dirty than 320i, 325i, 330d (these cars I have been driven for some time). Simply a layer of black stuff coated inside the pipe. These propose another question: carbon residue. Is carbon residue a series problems with this direct injection engine? If so, anyway to clean and how often should do? 5. any other issues? That`s pretty much all I am concern. Any comments are greatly appreciated, thanks guys. |
04-15-2016, 05:03 AM | #2 |
432
Rep 1,602
N55 isn't any more reliable than an N54, excluding maybe wastegate rattle:
- Same HPFP - Similar injectors - Same need for walnut blasting - It's a BMW, it will find places to leak oil - Same water pump failures - Same coil packs N54 is still being produced and used by BMW. N55 is not really any more reliable - owners of them typically state this to justify either a newer vehicle purchase or justify their less mod friendly motor. |
04-15-2016, 05:54 AM | #3 |
Captain Rus
46
Rep 348
Its not as easy as n55 vs n54... For instance n55 vs early model n54 = n55 is the more reliable engine. Compare to 2011 n54 from 335is i would say around the same reliabilty. They had the time to iron out some kinks in the n54 motor.
04-15-2016, 07:01 AM | #4 |
183
Rep 1,082
The n55 head and valve cover design does a better job of not recirculating oil back thru intake and therefore has less carbon buildup in intake reducing frequency of walnut blasting.
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey mods: blackout grill, finishing rods, badges, Blacklines. |
04-16-2016, 02:05 AM | #5 | |
Eric_Y
103
Rep 456
04-16-2016, 02:06 AM | #6 |
Eric_Y
103
Rep 456
Yeah I didn`t look at N54, simply looked at N55 made after 2011 thanks for advice mate
04-16-2016, 02:07 AM | #7 |
Eric_Y
103
Rep 456
04-16-2016, 07:41 AM | #8 |
2203
Rep 3,336
Drives: X5 & E90 WTCC Widebody Racecar
But even that point isn't true. Most (if not all) early model N54's have had new HPFP's, turbos, etc installed due to manufacturer recalls, making them no less reliable than later model N54's or N55's.
04-18-2016, 08:12 PM | #9 | |
Eric_Y
103
Rep 456
I have driven a F30 LCI for some days and found B48 has an excellent thermo management system, but didn`t expect that N55 also has such a quick warm up. |
04-19-2016, 07:20 AM | #10 | |
266
Rep 952
The HPFP is not completely fixed and some N55 owners have had their replaces. The software fix in later model years for the N54 and N55 to run the low pressure pump before the high pressure pump has reduced the failure rate. N55 has a much better oil separator design and does not have the intake build up problems of the N54. I thought the N55 had a different injection system. You also don't hear about N55 owners having to change their injectors out (at high $) like early N54 owners. I could be wrong about this. A turbo is typically good for about 100K miles, depending on conditions. This applies to all turbos in my opinion. Having previously owned a WRX, even that turbo wore out at 100K miles.
bone stock
04-19-2016, 09:11 AM | #11 |
236
Rep 358
Yikes, I wouldn't do it unless it was under a CPO warranty. If reliability is what you're looking for, this car is going to cause way more headache than enjoyment for you. Of course it's always the luck of the draw, but with so many issues these cars have it's going to cause you problems at some point.
04-19-2016, 05:50 PM | #13 |
BimmerPost Supporting Vendor
24204
Rep 190,807
Reliability is important to you and you are considering N54/N55?
These are the best cars to own for fun driving and absolute cheap mod potential but they are not reliable thats for sure Surprisingly the engine is very reliable, problems occur with the supporting components
04-19-2016, 05:57 PM | #14 | |
2032
Rep 8,339
04-19-2016, 06:20 PM | #15 | |
9
Rep 236
In bold...Then don't buy a 335i, seriously. Previous 335i owner.
04-19-2016, 07:08 PM | #16 |
Eric_Y
103
Rep 456
reliability is important, but not means it can`t go wrong. I just don`t want a car to break down all the time. Certain well known issues like HPFP etc I can accept if they happens not quite often.
04-19-2016, 07:08 PM | #17 | |
24204
Rep 190,807
Othen changes that might be needed radiator, radiator lines, stock charge pipe Other than fuel pumps, water pumps and turbos the 335 is as reliable as any other BMW
04-19-2016, 07:30 PM | #18 | |
7478
Rep 10,120
04-19-2016, 07:31 PM | #19 |
28
Rep 583
61k miles and just had to have the HPFP replaced. 2011 E92 335i.
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
04-19-2016, 11:39 PM | #20 | |
Eric_Y
103
Rep 456
04-20-2016, 12:39 PM | #21 |
18
Rep 80
Hey, I'm in the same step as you, looking for a n54 335i, do your research on this forums regarding the common issues and then take it to a trusted mechanic of YOUR choice, make sure the previous owner isn't someone shady and I think you will be good.
04-21-2016, 02:08 AM | #22 | |
Eric_Y
103
Rep 456
Just one thing I notice is different from previous 325, the engine speed increases a little bit, say 200 rpm when I turn the steering wheel at stationary. Not sure if this is because the hydraulic power is supplied by the engine. |
