Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      04-15-2016, 04:54 AM   #1
S65V8
*_*
Drives: ...
M4 GTS KWCS settings?
Being that the GTS uses a KWCS 3 way coilover set-up, is there any literature showing the exact specs of the suspension set-up for the track they've used to get those amazing times? (alignment, damper settings, etc.)
      04-15-2016, 07:54 AM   #2
Captain Unknown GT4
Captain Unknown GT4's Avatar
557
Drives: GT4
Yes, that wil come in a book with car. Stock setting is Nurburgring record lap setting in terms of suspension. That setting is max out on frontlip and rear wing. Nurburgring is a normal road that, hence that suspension setting will be ok for street as well( except frontlip due to diffrent regulations in law i guess. they got flat modern ractrack setting also in book for us to set up. Love it:-)
      05-10-2016, 10:29 AM   #3
redrumm3
redrumm3's Avatar
417
Drives: M4 GTS, M3 GT4, E30 M3...
Here is some additional info I found on the suspension.
Appreciate 2
      05-10-2016, 10:36 AM   #4
rr006rbc
1203
Drives: '23 M440i GC
^^ Oh my god that's so cool..
      05-10-2016, 06:59 PM   #5
S65V8
*_*
Drives: ...
BOOM! Now that's an answer!
      06-10-2017, 01:51 AM   #6
smh_amg_m4gts
Faster on 2wheels
smh_amg_m4gts's Avatar
Drives: M4GTS
Anyone test new settings yet?
      06-10-2017, 11:13 AM   #7
vipergts
Drives: BMW E90 M3
I'm rubbish at this techy stuff
What is High speed compression and low Speed compression for example?
High speed as in it will compress quicker (less resistance?)
      06-10-2017, 11:37 AM   #8
Osiris
Osiris's Avatar
Drives: 1M
2011 1M  [0.00]
2016 M4 GTS  [10.00]
      06-10-2017, 03:58 PM   #9
M4_GTS
Hong Kong
1153
Drives: M4 GTS
They are not the same. The GTS coilovers are valved differently, different springs, different top mounts and different springs seats. Pretty much the only thing in common is that they use the same strut body.
      06-10-2017, 05:33 PM   #10
S65V8
*_*
Drives: ...
It's amazing how vendors on these forums have been marketing as such lol. lies...thanks for setting that straight...never bought them anyhow...
Appreciate 2
M4_GTS1152.50
VCP1390.00
      06-10-2017, 06:27 PM   #11
M4_GTS
Hong Kong
1153
Drives: M4 GTS
This pic shows it pretty well, just look at that solid ball bearing top mount in the rear, and the lower spring seats in the front.
VCP1390.00
      06-10-2017, 07:00 PM   #12
VCP
VCP's Avatar
1390
Drives: M4GTS BSM/F90comp/BSM M2CS
And this is just 1 reason why you can't take a M4, buy some parts(kWCS3 example) and build a GTS
      06-11-2017, 08:01 AM   #13
S65V8
*_*
Drives: ...
agreed, although I have to admit, it would be interesting to see someone to take one of the named "GTS Plus" cars created on the forums or from scratch (to try and recreate it w mods), and take it head to head on a track somewhere. Honestly, not a half bad idea for an episode on any of these shows, DRIVETRIBE should pick up the idea!
VCP1390.00
      06-11-2017, 12:00 PM   #14
M4_GTS
Hong Kong
1153
Drives: M4 GTS
The GTS is not just about lap times. It's about having a car that can be driven daily, with reliability of a 4 years warranty from BMW. It's also about having a car where all the parts tested to work together even in extreme temperatures or any climate conditions. When you get into a M4 GTS, and drive it for the first time, the car just feels special and that feeling cannot be explained.
      06-11-2017, 01:51 PM   #15
vipergts
Drives: BMW E90 M3
Thanks for this explanation
Would you Chaps say that the recommended settings for road suggested by the factory are pretty spot on?
      06-11-2017, 02:26 PM   #16
VCP
VCP's Avatar
1390
I would say lower springs to "track" height and leave dampers alone. If you do not have too many clearance issues. The car does not feel quite right in high setting. Anyone else feel this way?
      06-11-2017, 03:11 PM   #17
schnell325
Bored at work....
schnell325's Avatar
887
Drives: 2016 F82 M4 GTS//2022 M235iGC
Yup. After we lowered it to "track" setting, it felt more planted and the steering was just that much more fluid.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      06-24-2017, 06:39 AM   #18
Billy_BMW
United Kingdom
52
Drives: BMW M2 Competition
Spring rate differences:
OEM M4 GTS Triple Adjustable ClubSport
Front: 400 lbs/in
Rear: 685 lbs/in
M4 KW Triple Adjustable ClubSport
Front: 575 lbs/in front
Rear: 800 lbs/in rear
http://f80.bimmerpost.com/forums/sho....php?t=1323417
      06-24-2017, 07:41 AM   #19
S65V8
*_*
Drives: ...
Front: 400 lbs/in
Rear: 685 lbs/in
That seems like a pretty big jump in stiffness, very interesting.
Search this Thread:
Advanced Search
f80post
