Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Sticking rear right caliper E90 2.0d
      04-12-2016, 11:48 PM   #1
ydsparts
Drives: 320d E90
I noticed recently that the back left disk on my 2007 E90 2.0d was getting hotter than the other side. Stripped the caliper off and there was corrosion around the piston so replaced the caliper. The problem was still there after a test. I thought that the brake flexi may be damaged so changed that as well. Still the same. It only gets hot if you use the brakes but when you don't use the brakes, it stays only slightly warmer than the other side. This to me sounds like a sticky caliper or brake again. Any ideas as i am pulling my hair out trying to find what it is!
Al Cowan
      04-13-2016, 01:22 AM   #2
Calluhan
Calluhan's Avatar
United Kingdom
71
Drives: 2014 BMW 640D Gran Coupe
Have you cleaned the guide pins and the shoulders that the brake pads rest on the calipers mate?
      04-13-2016, 03:31 AM   #3
ydsparts
Drives: 320d E90
Guides were new on the recon caliper and the pins were cleaned up as well.
      04-13-2016, 03:58 AM   #4
Aragorn30d
175
Drives: E90 330d
check the handbrake isnt sticking on?
The other possibility is theres some air stuck which means the braking is imbalanced? Perhaps try bleeding all four calipers.
      04-13-2016, 05:21 AM   #5
Calluhan
Calluhan's Avatar
United Kingdom
71
Did you fit new pads?
      04-13-2016, 10:30 AM   #6
ydsparts
Drives: 320d E90
The car got new disks and pads all round about 800 miles ago. They didn't have hand brake shoes when I was getting the parts so these were fitted last week. I set the handbrake up as the manual and it wasn't catching when I was spinning the disk.
