TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Shift delay from park to drive and drive to neutral?
      04-12-2016, 04:23 PM   #1
petey_highboost
79
Drives: '10 335D
Noticed this the other day. Going from park to drive there is a delay in engagement and almost kind of bumps into gear like it has a shift kit. Going from drive to neutral takes a second to disengage also.
Park to reverse and reverse to neutral and vise versa is the samething. No SES lights and other issues besides the slightly harsh and delayed engagement into D from neutral or park and delayed disengagement from d to neutral.
Any ideas?
      04-12-2016, 04:38 PM   #2
HeatherM35d
99
Drives: X5d and 335d
Yeah, I'll let you know when I can pull the trans..
      04-12-2016, 04:46 PM   #3
petey_highboost
79
Drives: '10 335D
I'm gonna go ahead and say it's an issue with the mechtronic, idk
      04-12-2016, 05:26 PM   #4
ingenieur
ingenieur's Avatar
24
Drives: 2011 335d MSport
Have done a check of the transmission fluid level properly as described in ISTA? Basics first...
      04-12-2016, 05:37 PM   #5
petey_highboost
79
Drives: '10 335D
That's what I was going to do first
      04-12-2016, 05:40 PM   #6
HeatherM35d
99
Input shaft spline slopping inside the hub.. Or planetary gears ., my expert prediction.. Jajaaja
      04-12-2016, 05:42 PM   #7
shnaggs
73
Drives: TDi
I've noticed that mine has always been on the slow side. Have never gotten the bump you talk about, but I just assumed that this trans is just lazy when it comes to the selection of D,P, and R.
I just got my trans fluid and pan/filter switched out and no noticeable change.
      04-12-2016, 09:26 PM   #8
HeatherM35d
99
Petey maybe you should mention in this thread that you were doing boosted launches and "hot laps" at the drag strip.. I'm sure there's a bunch of guys here that build these transmissions jaja
      04-12-2016, 10:22 PM   #9
petey_highboost
79
Drives: '10 335D
That's racin slick
Pencil in with you in summer '17?
      04-13-2016, 07:14 AM   #10
GaryE30
COAL FED
74
Drives: 335d, M3, X5
I have noticed that while in drive, if I bump it into neutral, it takes about 1 sec. to disengage. If I take my foot off the brake at the same time I shift to neutral, the car moves forward slightly then stops moving forward under load when it finally disengages.
So, yes, I have noticed similar delays.
