Xi front ball joint?
04-12-2016, 03:54 PM | #1 |
851
Rep 2,793
Does anyone have the correct way or sure method to extract ball joint from knuckle on front of e90 x-drive.....going to tackle this job soon but still unsure how to proceed even after reading here.
TIA |
04-13-2016, 08:19 AM | #3 |
40
Rep 669
http://www.pelicanparts.com/BMW/tech...eplacement.htm
That procedure shows how to remove the ball joint. Quite easy. |
04-13-2016, 08:25 AM | #4 | |
851
Rep 2,793
The ball joint is pressed/bolted to knuckle...and a bigger pain to remove. I'm just wondering if there's a specific puller that extract it without brute force. |
04-13-2016, 08:48 AM | #5 |
16
Rep 34
You could use the universal harbor freight wheel hub bearing press to remove and press, additionally you could freeze the ball joint, apply some lubricant and heat up the knuckle right before pressing.
http://www.harborfreight.com/fwd-fro...ers-66829.html Last edited by pierop; 04-13-2016 at 08:51 AM.. Reason: link |
04-13-2016, 10:54 AM | #6 |
Rep 63
Assuming you're talking about the wishbone and not the thrust arm... I just did this last week on my xi. Left side went great. Right side PITA. I used a press tool similar to the Harbor Freight one, but if I had to do it again I'd just order the whole control arm. I purchased an 1-1/2" black iron pipe nipple from HD since there isn't a collar in the kit that fits snugly onto the ball joint. The right side I tried heat, hammer, you name it and it wouldn't come out. Finally just let it soak with penetrating fluid for a few hours, gave it one last shot and it popped out. Be careful that the new ball joint goes in straight when you are pressing it in. Lot's of soap helps. The suspension needs to be loaded when you tighten the nut/bolt for the ball joint. You'll need an alignment after.
Side note: After removal and inspection I actually think my "old" one was just fine. |
04-13-2016, 11:52 AM | #8 | |
851
Rep 2,793
Guess I'm just going to wing it and hope it comes off easy! |
04-13-2016, 02:00 PM | #10 | |
851
Rep 2,793
Here's an appreciate for your effort |
04-15-2016, 07:55 PM | #11 | |
105
Rep 233
Drives: BMW
I did it my way!
mike |
04-15-2016, 10:39 PM | #12 | ||
851
Rep 2,793
How long it take with the air chisel,come out easily or did they need to be destroyed? |
04-16-2016, 07:16 AM | #13 | |
1208
Rep 2,835
Took it to a local indy shop at that point. They had them out in ~2 hours. I gave the mechanic an extra $50 for saving my ass. |
04-16-2016, 06:29 PM | #14 | ||
851
Rep 2,793
04-17-2016, 01:13 PM | #15 | |
105
Rep 233
Drives: BMW
Other Ball Joint: 45 minutes with air chisel & heat. Please read the post about the torx bolts. I bought a Lisle impact torx set. By the second ball joint, I had destroyed the bit. DON"T TRUST HARBOR FREIGHT QUALITY TORX BITS. Over the course of several days, apply heat, cool, and quality penetrant like Silikroil. You will destroy the ball joint but even OEM are relatively cheap. Last piece of advice, make sure you LOAD UP your radius & thrust arms prior to final assembly. If you don't load them up, you will destroy them before you get to a stealership to align the car. mike |
