Window won't go all the way up....not enough to seal no wind noise
04-12-2016, 12:51 PM | #1 |
Fastest 335 on Earth
39
Rep 426
I am getting some wind noise on the driver side.
I noticed the window doesn't go all the way up into the seal. I reset the window like 5 times. Changed the angle of it with the adjustment screw inside the door panel...Nothing is working. Look at these pics. One side it goes all the way up (pass. side) Drivers side does not.
E92 335i, 6MT- YouWish Single turbo, Precision 6466, Doc Race intake manifold w/port injection, Precision Raceworks coil packs and Stage 3 lpfp, 3.46 geared Mfactory LSD, VRSF 3.5" single exhaust, Toyo R888Rs, Spec Stage 3+ clutch, DSS axles, RTD shifter, Motiv, boost box and flex fuel, WOTBOX, MOTIV tuned...and much more
04-12-2016, 09:19 PM | #2 |
39
Rep 426
Any post I make...no responses lol kinda funny
04-13-2016, 09:57 AM | #5 |
39
Rep 426
Yep, I did that like 5 times.
04-13-2016, 11:43 AM | #6 |
1007
Rep 2,108
I think diagnosis will require removing door trim and vapor barrier and then observing glass movement and inspecting the channels and around for anything restricting the movement. Before that you can start by checking the visible door glass channels around the window frame for anything stuck there preventing full movement
04-14-2016, 09:09 PM | #7 |
39
Rep 426
I took the door panel apart, Looked at everything. Might have to bring to stealership
04-18-2016, 11:42 PM | #8 |
39
Rep 426
this is annoying
04-19-2016, 05:35 AM | #9 |
187
Rep 589
How did you try to adjust it? The Bentley manual has a long procedure for it, but in involves special tools.
It basically says to delete the power window initialization, remove the weatherstripping from the window channel, loosen the two adjustment nuts and then the window can be moved around. Attach a suction cup to the outside of the window and move it up until it's aligned correctly. The retraction depth at the upper back corner of the window should be 3.5mm +- 0.5mm. |
