335i problems with JB4?
04-12-2016, 12:45 AM | #1 |
93
Rep 183
I have a jb4 piggyback on my car with FBO (catless dps, fmic, etc) and whenever pulling through the gears in map 5 the car goes into limp mode around 5-6k rpm and the dealership looked at it and said they needed to replace the intake air temperature/pressure sensor, is this sensor going out a common issue with the jb4?
04-12-2016, 01:12 AM | #2 |
Գեվոջանյան
301
Rep 1,103
A lot of things can become a common issue when you install a JB4.
Current: 23 Frozen Gray M8 Comp GC, 22 Viola Parsifae Lamborghini Urus, 11 Fire Orange E92 M3 6MT, 07 BSM E60 M5 6MT, 00 Imola E39 M5
Previous: 2019 BSM F90 M5 Comp, 2019 Giallo Auge Lamborghini Urus, 2011 Silverstone E92 M3 |
04-12-2016, 03:03 AM | #4 |
84
Rep 971
have you got the codes? that would be useful in assessing what the issue may be
2016 M140i
07 E90 335i: JB4, Trebila BEF, BMS DCI, VRSF DPs, Scoops, 19" CSL Reps, 5" ETS FMIC, VTT Inlets, BMS CP, HKS BOV, BMS Meth Injection - sold |
04-12-2016, 03:55 AM | #7 |
4542
Rep 11,903
Check the boost safety settings in the JB4 tuner program
Default is 8 psi If you dont increase it, the JB4 will hit the over boost safety and shut you down |
04-12-2016, 02:37 PM | #8 |
BimmerPost Supporting Vendor
24204
Rep 190,807
Thread is a bit misleading in my opinion, the problems is with your car not the JB4
Post your codes and a datalog for best help
04-12-2016, 03:51 PM | #9 |
58
Rep 665
The default boost safety setting is 18 psi, not 8 psi.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
04-12-2016, 03:58 PM | #10 |
115
Rep 342
I had the same problem with my 335. Mine didn't give me any codes though, but these are some common problems...
- Bad Coil(s) - Bad Plug(s) - Leaking Vacuum Lines - CPS Sensors - Vanos Solenoids - Leaking Waste Gates - Faulty HPFP - Faulty Injector - Carbon Build Up (on intake valves) - Valve Cover / Valve Cover Gasket See if you are lucky enough to get a code, if not start to check some of the above items. Probably a combination of small problems. I just replaced a lot on my 335 and the problem seems to have disappeared. Good Luck!
2007 E90 335xi | 400WHP // 430WTQ
04-13-2016, 03:23 AM | #11 |
4542
Rep 11,903
04-13-2016, 08:50 PM | #12 | |
Ricebanger
24
Rep 260
hey check out my post i have the exact same --- except its stuck in engine low power mode we checked the car it read the IAT was -40c or something obviously broken I think the IAT is measured on the N55 on the TMAP sensor on the chargepipe --- and the JB4 mates to this sensor. coincidence? getting these problems makes me want to take my JB4 off and go stock |
04-21-2016, 12:16 PM | #13 |
93
Rep 183
So I opened up the fuse box and checked out the jb4 and all I smelled was burnt silicon/plastic, I returned the car back to stock since I'm 99% sure the board burned out, I'm going to be buying a procede from a friend and try that out instead, also ordered new plugs and coils
04-21-2016, 12:19 PM | #14 | |
93
Rep 183
04-21-2016, 12:30 PM | #15 | |
24204
Rep 190,807
I strongly recommend against getting a product that is discontinued (Procede)
04-21-2016, 12:38 PM | #16 |
93
Rep 183
04-21-2016, 12:43 PM | #17 |
24204
Rep 190,807
Havent seen a Procede being sold new for the last 2 years
