The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > JB4 Or MHD
      04-11-2016, 09:39 PM   #1
BryanDJHP
56
Drives: 2008 BMW 335XI
Yes there is a lot of threads on this. I want current advice. My car has been walnut blasted. And is up to date on all maintenance. I have stock DP's and FMIC. If I go with JB4 I could go to MAP1 or MAP5 for a less aggressive tune. Is there a less aggressive MAP for the MHD so I don't end up overheating until I order my new FMIC.
So my car is basically stock.
-On 91 Octane
-DCI
-Walnut Blast
-New Injectors & Coils
-Stock FMIC
-Stock DP's
I just don't wanna push my car to much and mess something up. I know that with the MHD people push around 18-19 PSI. I don't track my car but do go to BMW meets from time to time and push my car to the limits.
      04-11-2016, 09:46 PM   #2
BryanDJHP
56
There she is
      04-11-2016, 09:47 PM   #3
BryanDJHP
56
Last ones
      04-12-2016, 04:00 AM   #4
Socket
Socket's Avatar
4542
Drives: 335i
2008 BMW E92  [0.00]
-On 91 Octane
-DCI
-Walnut Blast
-Stock FMIC
-Stock DP's
MHD pump maps... you only hit 188-19 PSI if you floor it
Drive normally until you get your FMIC installed and you shouldnt have a problem
      04-12-2016, 09:41 AM   #5
BryanDJHP
56
And JB4? Isn't map 1 only 15 PSI
      04-12-2016, 09:57 AM   #6
Viorage
Drives: BMW 335i
Mhd
      04-12-2016, 10:18 AM   #7
SilberSurfer
SilberSurfer's Avatar
Drives: 335is
Originally Posted by Viorage View Post
Mhd
Don't forget to replace the charge pipes as well.
      04-12-2016, 10:30 AM   #8
ilicboris
ilicboris's Avatar
77
Drives: 2009 E90 335xi
Why not both?
      04-12-2016, 02:35 PM   #9
mike@x-ph.com
BimmerPost Supporting Vendor
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
Boost on its own does not mean much ... MHD hit more boost but way less timing
Both (JB4 or MHD) are safe for a stock car
https://x-ph.com/sale/
Phone number 702-494-9435
      04-12-2016, 04:58 PM   #10
BryanDJHP
56
Thank you. How safe is it to run MHD on a stock car with nothing but stock IC? Just don't push it to much basically?
      04-12-2016, 06:39 PM   #11
unrealii
75
Drives: '09 335 E93 6MT
Both are great platforms. I am very happy with MHD. I had JB4 and back end flash, but the drivability was too rough. The mhd flash, the car behaves more like oem.
Convertible | Manual | M-Sport | MHD Stage 1 + FMIC | 335is Clutch | ER CP | RB Inlets | VRSF 5" Stepped FMIC | M3 F/R Control Arms | KW V3 | Hawk HPS Pads | Stoptech Slotted Rotors | Blackvue DR650-2CH Dash Cam | LCI Taillights
      04-12-2016, 09:00 PM   #12
M335Xi
M335Xi's Avatar
Drives: 2007 335i e92
JB4
      04-12-2016, 10:05 PM   #13
BSM n54iS
BSM n54iS's Avatar
2685
Drives: '11 335is | '16 Macan Turbo
Why even tune...you should have more than enough hp w/ those decals
Sorry but somebody had to say it right? Lol, MHD all the way
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete
      04-12-2016, 10:19 PM   #14
Jake335is
Jake335is's Avatar
Poland
64
Drives: 2011 335is
You're the most confusing forum member!!!!
Appreciate 2
      04-12-2016, 10:22 PM   #15
Riceball777
163
Drives: S2000 618whp/ e90 335i
Jb4 with the back end flash as well as the jb4 connect kit. It's a great setup. I can log and see my gauges as well as my ethanol content on my phone all via Bluetooth.
2007 e90 335i
pure stage 2 DD turbos, rb inlets
      04-12-2016, 10:23 PM   #16
E92KS
HashSlingingSlasher
E92KS's Avatar
Drives: E92 335I
SHOTS FIRED! I REPEAT..SHOTS HAVE BEEN FIRED.
      04-12-2016, 10:33 PM   #17
Manberg
Manberg's Avatar
Drives: 2011 e90 335i
So why did this kids post count not change?
Anyway... I chose JB4 for its continued support and simple install. My first performance mods were JB4 and BMS charge pipe.
M-Sport, 6MT, PPK, JB4 ISO + Rev.3, VRSF 7'' FMIC, VRSF Catless DP, BMS Charge Pipe, MFactory LSD, Öhlins R&T, M3 Control Arms, Rogue 6MT Bushings, Remus Exhaust, Duke Dynamics CF Diffuser, Cyba Scoops, VMR VB3 19s, BMS Clucth Stop
      04-12-2016, 10:41 PM   #18
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
MHD Custom Tuning
Make sure to get a good look at boost and what shop temps were. This is an easy 500 whp in lower temps
  • Kohlefaser Luft-Technik Induction System (by ECS Tuning)
  • ClutchMasters Twin Disk FX850 Clutch and SMFW
  • AR Design Catless Downpipes
  • ER FMIC
  • ER Chargepipe with ER Tial BOV
  • VTT 2.0" Silicone Inlets
  • UUC Trans Mounts
  • Stock Fueling System
http://datazap.me/u/buraq/v28-4-bar-...=20&zoom=37-93
      04-12-2016, 10:46 PM   #19
BSM n54iS
BSM n54iS's Avatar
2685
That reminds me:
I was coming back from a BMW MEET in Mexico "Denver" and I saw a M4 next to me and wanted to see how I would hold with a JB4.(EVERYTHING WAS DONE IN MEXICO)
Long story short we did like 4-5 races from a dig and rolls, after the last roll I get to about 135MPH and "Engine Reduce/Malfunction" came on. I pulled over to the side turned of the car waited like 10 min and turned it back on and it was gone. I drove it normal the whole way home but decided to floor it again to see if it would show up. Got up to 95MPH and nothing appeared. Now my question is what am I looking at for cost and fixing? What could this mean? Could it be an injector/coil? Temperatures stayed average so that was not it.
Oh yea I've heard of Denver, Mexico...that's the vacation hot spot with the nicest resorts where all the F1 drivers go during the off season right
So this morning when I was getting ready for work I let my car warm up for the good average 15 minutes when I came back to my car I came upon the low oil light I got really really scared and went to the nearest AutoZone to get some oil. For some reason I decided to turn off the car and just turn it back on to see if it still said it, after 15 minutes or less I check the oil again and it says that The car is at a good level. I am probably going to take it to BMW soon and see what it is do you guys know what it could be? And to make it clear the picture I posted is how it looks like now. Before that it said car needed oil. I'm only 19 my budget is kind of tight any ideas of what it could be
Funny thing, i used to live of 123rd and Holly, no apartments or colleges nowhere near..
WHO THE FUCK IS THIS GUY?! BAN! hahaha
      04-12-2016, 10:57 PM   #20
E92KS
HashSlingingSlasher
E92KS's Avatar
Drives: E92 335I
@ OP
      04-12-2016, 11:06 PM   #21
BSM n54iS
BSM n54iS's Avatar
2685
Paid a friend $40 to make this for me! and I can say I'm super impressed.
And how does this guy have time to drive to 'Mexico' from Denver when he's busy hanging unnecessarily and non-deservingly obscene M logos everywhere?
      04-12-2016, 11:25 PM   #22
Antetokounmpo
Antetokounmpo's Avatar
Drives: E90 6MT FBO; '18 F150 Platinum
Because he probably screenshotted them at the same time, meaning if bryandjp didn't post anything within the window the dude screenshotted them, the post count wouldn't change.
All I know is OP is full of shit. I've called him out before as well.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
