M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > New owners, how much clearance is there?
      04-10-2016, 04:03 PM   #1
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
Asking someone who has already taken delivery. I'd like to put 265s in front and 285s in the rear on stock wheels. This will give me more gription for less $s (simply buy 285s and take the stock 265s and mount them in front) and also give me better protection for the wheels. Can you measure clearance between:
The front strut and the wheel/tire.
Outer edge of the wheel/tire to inner edge of the front fender.
Rear shock and the wheel/tire.
Outer edge of the wheel/tire to inner edge of the rear fender.
Picking my car up in 2 weeks as the performance center!
      04-10-2016, 04:12 PM   #2
confusion
confusion's Avatar
Drives: 2016 M2
Yeah, can't wait to find out what we can actually do in this department.
      04-10-2016, 08:03 PM   #3
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
These tires shouldnt hit the suspension since it shares it with the M4. I'm worried about the liners and fender.
Current
AW BMW M2
Past
VO BMW 1M
      04-10-2016, 08:05 PM   #4
Pyrat 2
Pyrat 2's Avatar
Yep. That why I want some actual measurements.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      04-11-2016, 09:01 AM   #5
David1
David1's Avatar
812
Drives: 09 E92 09 X5
There is big lip on the front fenders that I was checking out this weekend on the M2 that showed up at my dealer.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
      04-12-2016, 06:36 PM   #6
Pyrat 2
Pyrat 2's Avatar
Anyone care to make these measurements and post?
      04-12-2016, 09:21 PM   #7
Tag
this is the way
Tag's Avatar
18127
Drives: N-1 starfighter
I'd be shocked if you go two size up front and rear and don't run into any rubbing. I like the idea though, I'm rooting for ya!
      04-12-2016, 09:26 PM   #8
Pyrat 2
Pyrat 2's Avatar
I'll order wheels with custom offsets if required. I squeezed 255/35 on the front of my 1 er with no fender work or crazy suspension mods. Had it down to the mm though with offset.
      04-13-2016, 05:23 PM   #9
jcrb
Not-So-New Member
jcrb's Avatar
Hong Kong
103
Drives: 02 E46 M3, 16 F87 M2
That's absolutely a bad news for people like me who wanna go for some more aggressive offset......
Current: 2016 BMW ///M2 Black Sapphire Metallic / 6MT
SOLD: 2002 BMW ///M3 Matte Grey Metallic / SMG
Core of WrongFitmentCocks
      04-16-2016, 12:32 PM   #10
OrangeCrush
1236
Looked under the car last night and there is at least an inch between the rear tire and rear shock, probably more, didn't measure it. And this is to the dust cover over the shock so it has movement if it was rubbed. Tried to look at the front but it's too low to look under without lifting. Maybe I will drive up on ramps today to take a look.
Current
AW BMW M2
Past
VO BMW 1M
      04-16-2016, 01:30 PM   #11
Pyrat 2
Pyrat 2's Avatar
Awesome. Thanks. 1 of 4 measurements done. I take a string with a nut tied to the end to measure the fender clearance holding the string to the inner fender edge. For the front you should be able to turn the wheels full lock and get the strut clearance. The struts and wheels turn as one so it works fine. No lifting the car required.
      04-16-2016, 09:17 PM   #12
OrangeCrush
1236
I just went out and measured the rear. It's actually closer to 1.5" to the shock dust boot. Now, if you went this close you would probably rub on the liner somewhere.
Now to the fender. I used a straight wood shim and put it on the outside of the fender then "eyeballed" it perpendicular to the ground. The edge of the tire was about even to the fender. (The rim protector portion of the PSS) If you follow the camber instead of straight up and down (nut on string method) you might have 5mm clearance ...Maybe even 8mm but I think it would give you the "flush" look...not quote hello flush though...lol!
I will do the fronts tomorrow if I have time while the kids are sleeping.
And remember, all of thsee measurements are on a stationary car.
Current
AW BMW M2
Past
VO BMW 1M
m2
